Aluminum slot wheels rule...
Quick dumb question
Are bedsides on 67-72 trucks bolted on, bead welded or both?
Re: Quick dumb question
They are bolted on with a spot weld by the tailgate area.
Just one spot weld? Thanks for the info.
They have them on both sides of the gate at the bottom of the bed. The last one I took apart had 2 small spot welds on each side, some are harder to cut than others. They keep the back of the bed from flexing I would guess.
Where's my beer?
Here you go jake!
Paul How do you make the invisible, visible?.........You take it away. |
Perfect. Thanks guys. Just brewing up some plans.
![]() Join Date: Feb 2004
That's a great picture Paul
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Happy Camper
That was sure nice of you to cut your truck apart to answer that question, this forum is awsome.
RIP El Jay! Love you brother! |
If it was all unbolted do you think moving it back and forth would break the weld? I got one I need to disassemble and OKLAHOMA has practically been under a fire ban since December. No torches in this grass field for doing that. there's plus 100 cars that could burn up. It will be May before I can get to it though.
someday it will be done!
Bastards!WTF is wrong with a bolt!I have the impact all geared up and ready to go.I get all the bolts out and yet there's something holding.Doesn't this seem like a cheap shot by GM?WTF would make you do something like this?There're all kinds of places to put another bolt,why torture us like this?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#11 | |
Get a spot weld cutter and a cordless drill.
Tim |
#13 | |
In the pics notice both the vertical and horizontal welds. (grind marks) The welds are in rather tough to reach areas too. Using a grinder or cut off wheel will get you started but typically will hit the body of the tool in the corners before you'll get all the way through the weld. Last edited by vtblazer; 03-18-2006 at 08:43 AM. |
#14 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#15 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Very easy to cut with a cutoff wheel on you air powered cut off tool... May even be able to use a dremel could take you for ever that route though..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
