03-17-2006, 10:58 PM | #1 |
Still Green but learning
my truck is leaning.
My truck leans a little to the front pass side when parked on a level surface. I assume it is a worn out spring but is there anything else I need to look for?
Also if it is the spring how hard is that to replace and do I need to do both if I do one? thanks
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
03-17-2006, 11:12 PM | #2 |
Re: my truck is leaning.
It is not hard to replace the coils up front. Just take the tension off with a floor jack, remove the lower ball joint, then let the jack down. Be carefull with your brake lines. You should replace both springs. They are both 34-39 years old and if one is sagging, then when you put in a new one, the other side will look sagged.
03-17-2006, 11:25 PM | #3 |
Blank
check radiator support mounts too mine rotted out and fell to the passenger side
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
03-18-2006, 12:00 AM | #4 |
Custer had a plan too.
It would be easiest to park on a slight hill.
Most fun would be to drink enough beer to adjust for the tilt.
72 K15 GMC (aka Big White) Performance Rockers, Cab Corners, and Floors Fossil Fuel Glutton Neighborhood Nuisance 98 BMW 540i for Speed (Sold ) 05 Subaru Outback for mileage |
03-18-2006, 12:02 AM | #5 |
Hey I like the last suggestion
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
03-18-2006, 12:08 AM | #6 |
a bigger tire on one side would do it to, lol
common sense isn't so common anymore |
03-18-2006, 08:21 AM | #7 |
Park on a flat surface and measure from the ground to the frame on both side to be sure it is the spring before you buy them. The rubber mounts might be shot or like said above the rad support rust or front cab mount/support could be gone.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
