Old 03-18-2006, 10:42 AM   #1
OJ1988
Just a car guy
OJ1988's Avatar
Truck won't idle
Okay, as I am starting to drive this truck, I guess I am shaking out some bugs.
First a little background. I bought this truck a month ago. It is an 86, was a 4.3 but the guy I got it from swapped in a junkyard 350. He said it came from an 85 van.
It has a Quadrajet carb, and looks all stock. There are a few things not hooked up, egr, charcoal canister. And the fast idle solinoid, I do not know were it should get vacume from, it was not hooked up when I got it.
I have put about 200 miles on it and it ran well.
Then the other night, we drove around the town and got something to eat. After eating, we came out and got in the truck. It had been sitting for about 1.5 hr. I started it up, and it was idleing real rough and low RPM, If I gave it a little throttle it would smooth out.
Drove it home. As long as you were giving it a little gas, it was smooth. But without it, it would shake and stall.
The next morning I got in it and it ran fine, then that afternoon, same thing.
So, I started looking over things, cleaned the carbn with some carb spray, changed the oil and filter (needed this anyway). Put some new plugs, cap and rotor, and wires.
The plugs actually looked pretty good. I put some Lucas fuel treatment in the tank, and changed the fuel filter, it looked real bad.
After these changes it ran much better, but once it warmed up, it did the same thing.
I checked for vacum leaks but could find none.
I tried to check the timing, but there is no timing tab.
The top gasket on the q jet does look bad, and leaked slightly, but spraying around it with carb cleaner did not change anything, like a vacume leak would.
So, I am at a loss. I am going to pick up a manual to check all the vacume lines and such, and try an find where to hook up that fast idle.
The only thing I can think is the carb, think a rebuild is in order?
OJ1988 is offline   Reply With Quote
Old 03-18-2006, 04:53 PM   #2
cutter61
cutter61's Avatar
Re: Truck won't idle
my 305 was doin the same thing-turned out to be the cams on the choke and throttle,they were gunked up pretty good-cleaned em up but turned out the throttle lever bushing was gone-ended up getting the carb rebuilt,the kit was only 35 bucks cdn. and an old school mechanic did it in his living room(not too many shops want to rebuild carbs anymore)take the throttle lever and try to wiggle it up and down,if the truck changes idle speed the throttle bushing may be shot-try to hookup the vacumm lines and check for cracks-or could always go with a new edelbrock-my 2 cents-good luck
If ya don't get at it when ya get to it,You won't get to it to get at it again.
cutter61 is offline   Reply With Quote
Old 03-19-2006, 12:03 AM   #3
84 400
Sb 400 club
84 400's Avatar
man i got a similar problom. mine is the q jet but it won't kick down. races on and on ande with no pedel in drive it goes along at 25!! What went bad here?
is it solonid related?? 1985 305.
Thankks alot
sorry i am still in school and my spelling needs help!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-20-2006, 04:08 PM   #4
84 400
Sb 400 club
84 400's Avatar
any one can answer my ?
i would really appresiate it
1985 C10 LWB Sold
Old 03-20-2006, 05:12 PM   #5
OJ1988
Just a car guy
OJ1988's Avatar
Well, I pulled that carb off, and there was raw fuel in the intake, so a buddy of mine is rebuilding it. My center intake bolts were lose as well, so I hit all the intake bolts and exhaust manifold bolts as well.
