03-19-2006, 01:16 PM | #1 |
Primer...
Are there any decent looking permanant primers out there for body panels that protect against rust very well? I ask because im not going to have the $$$ to paint my truck and its going to be my daily driver. Im thinking of leaving it in a dark grey primer and putting some kind of hand painted oval marking on the doors {ie: so-cal speed shop kind of thing, but not that} Im going at this thing one section at a time and this is down the road but im just curious.
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere... -72' C10 350 Auto 12 bolt, runs 19's?? drives to work! |
03-19-2006, 01:25 PM | #2 |
Re: Primer...
Someone has mentioned on here before that Sherwin Williams has whats called a "shiny" primer that protects really well. I will be looking into this as well as I wont be painting my truck for a while either.
SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD |
03-19-2006, 01:44 PM | #3 |
its all about the +6 inches
Re: Primer...
Any sealer will give the look you are looking for, and if you want something other than gray, you can tint it.
03-19-2006, 03:11 PM | #4 |
Re: Primer...
You need to spray flat-clear over your panels to provide "uv" protection from the sun. There are no primers on the market that you can use that are permanent from protecting from rust. All primers contain "talc" that makes the ease of sanding them and absorb moisture. Good luck.
03-19-2006, 03:48 PM | #5 |
Questionable
Re: Primer...
Eastwood's Rust Encapsulator.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-19-2006, 04:00 PM | #6 |
Short, Fleet, Slammed, V8 Club
Re: Primer...
What about using Transtar two part epoxy primer. I put that stuff on the doors of the S-dime when I shaved the handles. It was on there for a good 3 years sat outside every day and was driven everyday. It faded from a semigloss to a flat over that period of time but there was not one spec of rust. Now I have to tell you that crap is hard as a brick after 3 years of weather and then trying to sand it off. Once you get through the outter layer you are ok but that top one is a real beast.
03-19-2006, 04:45 PM | #7 |
Re: Primer...
epoxy primer is a sealer.
03-19-2006, 06:40 PM | #8 |
Re: Primer...
Sherwin Williams makes a "shiny primer/ surfacer" that is weather proof. It comes in 8 different colors. They claim it can be sprayed on and used like a single stage paint. Here is a photo of my truck with the grey on it.
03-19-2006, 06:42 PM | #9 |
Re: Primer...
I've been using PPG DPLF mixed with reducer to make a primer/sealer. Body filler/surfacer/basecoat/topcoat can be applied over it at any time.
03-19-2006, 06:44 PM | #10 | |
Re: Primer...
03-19-2006, 06:45 PM | #11 | |
Re: Primer...
I have to disagree with this, however - epoxy primer is not a sealer by nature unless you're referencing a particular one. They're made to allow gas to escape - for example, if you're applying over an etching primer. |
03-19-2006, 06:46 PM | #12 | |
Re: Primer...
03-19-2006, 07:59 PM | #13 |
Re: Primer...
I am refering to Sherwin Williams SpectraPrime series P30 surfacer/primer/sealer. I sprayed this stuff on and went back 40 days later and wet sanded it. It has a gloss finish which eliminates the need for painter's guide to find the low spots. The low spots will continue to be glossy after the wet sanding. The Sherwin Williams rep explained to me that you can spray this on and move the vehicle or part outside and come back to it at a later time. It is as weather proof as paint until sanded.
Check out the Sherwin Williams web site and look up the P30 line. |
03-19-2006, 08:15 PM | #14 |
Re: Primer...
if it is temporary , while waiting for paint, you might as well paint it with a cheap paint, if u want the primer look , the best way is to pick a grey and add a flatener, if it is garaged all the time, shoot a sealer, if it is out in the weather, primer will fade quick, most of your high end sealers cost more than a cheap one shot paint.
03-19-2006, 08:40 PM | #15 | |
Re: Primer...
03-19-2006, 09:03 PM | #16 |
Too Dumb To Know Better
Re: Primer...
John Deere "Blitz Black".
03-19-2006, 09:47 PM | #17 |
'71 chevy s.bed/s.side
Re: Primer...
I've used the SW P50 and was told by the supplier, that happens to be a true body man, that the P50 is a sealer and it does very well with moisture. When applied, it dries to a low lustre finish. Here in Tidewater, VA. we have some very humid weater and this seems to be doing very well..You can Google SW and view their product data sheets.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
03-19-2006, 10:11 PM | #18 | |
Re: Primer...
http://www.sherwin-automotive.com/me...glish/5219.pdf |
03-19-2006, 10:30 PM | #19 |
Re: Primer...
I was advised that unless you sand through, it can be used as a sealer and painted directly over. I will personaly vouch that it is the best surfacer I have ever used. It is a bit harder to sand until the gloss is removed, but seems to be a very heavy fill surfacer. I personally use it often, and have even rolled it on to spot repairs to save in masking and booth time. I feel that it is a new product with great potential.
03-20-2006, 02:36 AM | #20 |
Re: Primer...
i've been using omni mp170 epoxy primer but you only have 3 days to cover it or it must be reapplyed before proceding i think ppg dp 40 you get 5 days i don't like this.is the sherwin williams stuff the same way? i was at sw saterday{house paint} he told me they cant even buy auto paints. where do you get this stuff?
common sense isn't so common anymore |
03-20-2006, 08:13 AM | #21 | |
Re: Primer...
It was over 45 days before I sanded and painted. Check your local NAPA store, they carry it here in MN. |
03-20-2006, 10:25 AM | #22 | |
Re: Primer...
The "40" is the color of the DPLF, so when you see DP40LF, that just means grey DPLF. |
03-20-2006, 10:28 AM | #23 | |
Re: Primer...
Good thread! |
03-20-2006, 03:21 PM | #24 | |
Re: Primer...
03-20-2006, 03:48 PM | #25 | |
Re: Primer...
