My 5.3 swap. Help!!!
Ok I have been reading for days now and this is what I think I am going to need.I am doing a 04 5.3 and 4L60E in a 72 2wd blazer. Am I going to have the clearence issues that the LS1 swaps have with the accessories? I have already won a auction on ebay for a set of electric fans off a 98 camaro, will my factory radiator work with these? I guess ece's motor mounts are the way to go? Will they bolt right up to the 5.3 and the blazer? Were do I need to get me a tank with the fuel pump? What about the 4L60E, will the tubo 400 crossmember work and what kind of mount do I need? I think I am going to order the kit from lokar were I can use my coulmn shift. I guess I will have to have the driveshaft shortened. What else do I need to get? I am going to send my harness to current performance to get it made a stand alone. Who is the cheapest on programming computers? Thanks in Advance, Kade
Re: My 5.3 swap. Help!!!
ece mnts are percise and nice (im a poet), but IMO they are ordinary. auto x member will work , but will need to be located back (shifty has lots of pics in his signature of both xmember and ece mounts) yes they'll mount up to the 5.3 no problem. fuel tank i would highly recomend mark AKA fuelcellguy, not only the cheapest but highest quality too. as far as computer programming im leanong towards jesse at wait4me tuning.
good luck and one thing you didnt mention is do you want headers or manifolds? im going the header route, and when i get it figured out ill post pics and tell ya how i modified them to fit. good luck post lots of pics for us Last edited by 68 short step; 03-19-2006 at 04:28 PM. |
#3 | |
Let me know how you are coming on yours. |
I am using wait4me for my harness and reprogramming, they only charge $320 including shipping. My harness and computer should be back this week, i will let you know how it looks.
#5 | |
![]() Join Date: Mar 2005
speartech fuel injection do fine work too, and are very helpful over the phone(wich is very important in you situation) im waiting for my harness back, check LS1tech.com they are few diferents set ups for the fuel system,but for that beauty,i think you want to use in-tank fuel pump from fuellcellguy, im putting a 6.0 with a 4l80 from a 2004 van on a 72 blazer 4wd frame, board member shifty is installing a 5.7 in his truck with a t-56, i learn a lot from reading his posts, i think we going to see a lot of ls1 in 67-72 trucks in the near future.Good luck.
#7 | |
Isn't there clearance issues with the AC compressor on this swap. YOu have to notch the frame?
#9 | |
#10 | |
Questionable
really? for me, the alternator was about half inch cleared of frame, but A/C compressor wouldn't fit. I am using 5.7 LS1 though.
can someone provide more information about Wait4Me's PCM and harness services? Speartech does killer work with your stock harness - $450 and they completely re-wrap your harness, add VATS delete when required, add ... well, here is what they do: Quote:
Also, what exactly are you having modded on your PCM and why? Just curious. jkade: More info on my swap can be found in my ls1edit thread - I think we've been PM'ing on that forum, I think?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
wait4me removes all uneeded wires and anything else that you ask them to. They claim it is an 8 wire hookup after they rework it. On the computer they will remove anything you ask them to and reprogram it for any modifications you have done. On mine I had them remove the vats, rear O2's all emissions stuff, 4wd, transmission shift points and wiring, and had programed for 92 octane. Jesse is a member on ls1truck.com if you want to ask him any questions.
#12 | |
I talked to wait4me today and they said they would do my harness and computer for $320 including shipping. That is dirt cheap and I have only heard good things about them. Said it usually takes about three days on the harness.
#13 |
Questionable
ok, i've been hearing good stuff about them and i'm going to go through them. that's cheaper than anyone else has offered to me so far and they've got a great rep at ls1tech. i'll hafta give a PM over there. thanks for the info jkade.
they don't add all that extra fun stuff though ![]()
#14 |
Did you ask them how long it takes to reprogram the computer when you talked to them?
#15 | |
#16 | ||
Questionable
Something you will learn VERY quickly in this swap is, the more you skimp on buying things, the more problems and questions you will have later trying to put it all together. Do you understand what wait4me provides? You pay $340, they give lifetime reprogramming and hack your stock harness. What you get back is a re-wrapped harness: - 3 wires are exposed: 1 for starter, 1 for BATT power, 1 for ACC power - A/C wires exposed and labelled if you say you ask - You are required to figure out how to run all of your lines, fuses and relays for: 1. Cooling fan #1 2. Cooling fan #2 3. Oil Pressure Output 4. Malfuntion Lamp Control Output 5. Vehicle Speed Sensore Output to Speedometer 6. OBD11 Data Port 7. Tack Ouptut 8. Fuel Pump Relay Control 9. Plus 3 more wires for A/C if your leaving that in as well Would you pay $200 more to have: > All relays ready > All fuse blocks attached and in place > Plug-and-play, no cutting or splicing > Harness that is fully tested on a working engine before you get it > All extra wires (fuel pump, etc) in place and ready to hook up? Using the Speartech harness (or letting Speartech hack yours) is going to save you at least a day's worth of work and a day's worth of research, and maybe another day's worth of hassle. Makes the $200 more seem like small potatoes to me. ![]() If you want to see what a swap like this looks like, please click on the LS1tech link in my signature for a 13+ page thread with pictures of my entire install up to now. It will answer half or more of your questions. Last but not least, Wait4me DID do good work and DID return a great product (the harness) overall, labelled everything very well, and gave me a wire diagram. Very helpful. My only beef was: They didn't explain all of the extra work I would need to do and they had the WORST communication ever - I emailed about 10 times and got one email back later. I was waiting for days. Called twice - voicemail. No returned call. I was amazed to see (while talking to someone over at LS1tech) that a PM was actually returned - someone was just asking for pricing and it took days to come back. This is what you can look forward to with Wait4me (and don't expect them to give you status updates after you mail out, it won't happen): Quote:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 01-25-2007 at 05:37 PM. |
#17 |
Questionable
Wait....where did this thread come from?
#18 |
Cereal Killer
magic
