TPI anyone?
Anyone ever put a TPI motor in these trucks? Changed over from carb to TPI? What does it involve? I found a mid 80's camaro Z-28 in a junk yard and it has a complete TPI setup. Is this worth it?
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere... -72' C10 350 Auto 12 bolt, runs 19's?? drives to work! |
Back in the sticks
Re: TPI anyone?
For looks yes, but as far as gas mileage goes, no. Throttle response, yes!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 10-04-2007 at 08:38 PM. |
Keep On Truckin'
Re: TPI anyone?
I did it to mine an I think it's worth it. Mass Air Flow set up from a '87 Camaro and single belt serpentine set up from a '92 Camaro. I still can't get better than 14MPG with 700R4 and 3.08 gears. I've heard a lot of noise from people about how 3.08 gears with 700R4 would lug down the engine but it doesn't. Goes into OD at about 42 and at 70 is turning just under 2,000 RPM. Only down shifts up fairly steep grades. I hear of folks getting 18-20 in these trucks but I'll be dipped if I can....
red71cheyene has a Speed Density set up.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... Last edited by mocwon; 03-19-2006 at 06:47 PM. |
Old member
Re: TPI anyone?
I put mine in in 1989 and LOVE it. This is my everyday driver. Can't ask for a better truck motor combo. I also have the 700-R4 in it to. I made my own cold air intake for it also, solid upper water hoses also. You can see the mods on my www page.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
its all about the +6 inches
Re: TPI anyone?
mocwon, have you tried running the truck in 3rd and checkin the MPG like that?
#6 | |
Keep On Truckin'
Re: TPI anyone?
No, I'll do that this week and see what the results are and post them. Thanks....
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
Back in the sticks
Re: TPI anyone?
Longhorn, what will that tell you?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Re: TPI anyone?
that will confirm that his gearing is too tall... just like everyone tells him.
If the MPG stays the same, or even goes up, then it is obviously overgeared. If it drops by a small percentage...say one or two MPG, then again, chances are it is overgeared. If it drops by more than that...then I'm wrong and he is doing OK. But I'm willing to bet that his MPG will stay the same in 3rd gear. |
