Old 03-19-2006, 10:48 PM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
Carb Size for 454?
I have been fiddling with the 454 in my K-20.............It runs better, but falls on it face on a hill and still seems sluggish when you stand on it. The previous owner put a new Edelbrock on it, and I haven't checked yet, but I am wondering if he didn't go big enough for this size cube engine. What should I be running on it? Everything else is spot on, and it runs well, other than the problem I mentioned above, it just doesn't seem like its getting the fuel/air on a pull. I put all new filters/plugs/wires on it so it isn't any of that that is the problem, and it has an electric fuel pump that works really well.
Still haven't checked the block #'s, but I am wondering if this isn't a smog engine and it will be a turd?
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 03-19-2006, 10:52 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Carb Size for 454?
750 cfm to 800 cfm to 850 cfm depends on the cam size
750 for sure
rage'nrat638 is offline   Reply With Quote
Old 03-19-2006, 10:56 PM   #3
stepside454
stepside454's Avatar
if its a stock or near stock 454 Id use either a Q-jet or a 750 cfm carb.
Ive got a 770 Holley on my mild 454. John
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 03-19-2006, 11:00 PM   #4
TP from Cntl PA
750 for sure
It looked to me like a 650 or something off a small block, but I'll have to look closer................They got an adapter plate on it to make it fit. May have to go back to a Q-jet
Old 03-20-2006, 11:00 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm using a Jet Stage II 800 cfm quadrajet and my 454 seems to like it alot.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-20-2006, 11:47 AM   #6
MrC1
Dork For Days
MrC1's Avatar
750 for sure
Agree with rage'n, but you could probably get away with a 700 if you're in stock form and not spinning past about 5000 RPM. If you've got enough cam to need 6000 RPM, go with an 800. If 6500, go 850.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 03-20-2006, 02:31 PM   #7
Billla
Billla's Avatar
A Q-jet flows about 780 CFM, and even some fairly warm Corvette 454s shipped with them. I'd stick with a vacc secondary carb.
There are a lot of things to look at with the symptoms you're noting, but I'd be surprised if it's the fuel pump. My guess is a) timing advance or b) the point where the secondaries are kicking in or the metering rods.
I'd keep the Edelbrock and tune it vs. making a change. They're great carbs for engines making <= 1.2 HP/CID FWHP.
Billla is offline   Reply With Quote
