03-20-2006, 12:46 AM | #1 |
What size rearend?
I have an 1/2 ton 81 LWB with a 305cid and TH350C. What size rearend do I have? I am looking to buy some 3:73's for pulling and need to now the housing size.
03-20-2006, 01:38 AM | #2 |
Stepsides RULE
Re: What size rearend?
My 80 C10 305 + TH350C has 2.56 but who knows.
There's another post referencing gear sizes, might wanna check it out, too.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
03-20-2006, 02:15 AM | #3 |
I'm back with 2nd truck!
Easiest way to tell is to count the bolts at the rear cover. This will tell you what bolt size you have. It's probably a 10 bolt but it may be a 12 bolt. You also need to pop the cover off the differential to find out what carrier size you have unless you're wanting to install a new one. Count the teeth on the ring gear and the pinion. Divide smaller number into larger number and this will give you a gear ratio on what you have in there now. You will need this to find out what carrier you have. "Usually" the lower numerical numbers like 2.56, 3.08, 3.42 have a Series 3 carrier and a larger number gear ratio have a series 4 carrier. You can resue the carrier as long as you know what size it is and get the correct gear ratio for the carrier. If you want a 3.73 and you have a series 3 carrier you may have to get a thicker set from the manufacturer but need to contact them to be safe.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
03-20-2006, 09:28 AM | #4 |
79Big10 hit the nail on the head. I would say to probably have a 3.08. Not really sure what year they switched to the 10 bolt. But an 81 is around that time. Take a look on the rear end housing for a stamped number or a tag if you don't want to yank the cover off.
03-20-2006, 06:24 PM | #5 |
You get what you pay for
Brandon is correct. I think a 3 series carrier will go up to 3.73 on a 10 bolt, at least it did on my 85.
Mike 1985 Chevy C-10 |
03-21-2006, 01:53 AM | #6 |
I am looking for gears on Summit. It is a ten bolt. Would it be an 8.5?
03-21-2006, 02:03 AM | #7 |
Yes, it's a 8.5.
03-21-2006, 08:39 PM | #8 |
Parts and more parts
Look at Rand'ys Ring and Pinion website for more info.
03-22-2006, 12:24 AM | #9 |
Thanks everyone
