Old 03-20-2006, 11:05 AM   #1
big blue 72
Brake booster problem!
bought a brake booster from someone on the board and am having a problem with it.
the pushrod isnt long enough to bring the brake pedal back up to original position, so when it is hooked up the brake lights stay on.
i looked at the brake light switch and it wont adjust out long enough to raise it up . and it is welded on so i dont think it can be moved. what do i need to fix this?
big blue 72 is offline   Reply With Quote
Old 03-20-2006, 12:01 PM   #2
big blue 72
Re: Brake booster problem!
also, the brown/tan wire i removed from the prop valve. Does that need to be hooked back up somewhere?
Old 03-20-2006, 12:03 PM   #3
farside847
farside847's Avatar
This is actually normal. You will need to adjust the brake light switch to only turn on when the pedel is pressed.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-20-2006, 12:03 PM   #4
farside847
farside847's Avatar
more info:
http://67-72chevytrucks.com/vboard/s...d.php?t=163387
Old 03-20-2006, 12:29 PM   #5
big blue 72
Yup, reading the FAQ was how i got it in.
How do you adjust the switch position?
Brown wire?
Old 03-20-2006, 01:15 PM   #6
farside847
farside847's Avatar
Mine was adjustable. The switch at the pedal could be screwed in and out.
Old 03-20-2006, 01:29 PM   #7
big blue 72
thanks i will try that.
Old 03-20-2006, 01:35 PM   #8
Sweet72
Sweet72's Avatar
Brown wire is for your brake warning light and should go to the proportioning valve. If you didn't change out the prop valve to one without the switch it should just plug right in. I believe the brake pedal sits quite a bit lower with power brakes than manual if I remember correctly. This is normal.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
