Old 03-20-2006, 11:11 PM   #1
qksilver
72 burb 1/2 to 3/4
Just brought back a 3/4 LWB truck frame from Bills Bowtie. Took the senic route what a ride! 9% grade, 11% grade..........LOL
The questions, I am tired of doing frame swaps.
I want to convert/pervert one of my 1/2 72 burbs into a 3/4 2 wheel drive.
Are the frames the same, as far as strength?
Are the engine crossmembers the same? So I can swap just the suspension not the crossmember
The 3/4 truck frame is leaf , the burb coil. I am going to swap spring perches on to the coil frame. I measured and it will work.
Are the 1/2 burb rear crossmembers strong enough? or do I need to find burb 3/4 rear crossmembers for leaves( so they will work with the frame mounted tank).
Are 1/2 and 3/4 steering boxes the same?
I am building this to replace my 99 BB 3/4 burb as a tow vehicle so I want to make sure it is strong enough ( for the rear spring perches)
Any pix of a leaf spring 3/4 burb would be great.
SCJKOVACH@AOL.COM
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 03-20-2006, 11:46 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: 72 burb 1/2 to 3/4
Try posting this on ein the burb section, maybe that will help
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-20-2006, 11:50 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm pretty sure that the 3/4 ton trucks had some reenforcement... but only on the coil spring frames.
So if you were to do leafs, the frames would be the same.
Old 03-21-2006, 12:15 AM   #4
qksilver
Thanks, I looked at my longhorn but the gas tank part concerns me.......
Old 03-21-2006, 03:18 PM   #5
qksilver
Ttt
Old 03-21-2006, 04:04 PM   #6
uncle
I towed with a 1/2 burb with bags on the back for almost 2 years. Probably towed at least 40 vehicles. I will have a 354 dana coil spring rear from a 3/4 ton in a week or so.
uncle is offline   Reply With Quote
