Heads question
Will #882 heads from a 1975 have the right front bolt holes for a 72 application as far as the alternator mounting
Anything else that might cause me problems?
Fabricate till you "puke"
Re: Heads question
Yup, you are good to go
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
