Old 03-21-2006, 01:47 PM   #1
1969K10
1969K10's Avatar
Time to replace a manual locking hub
So, i've got an old closed knuckle D44, and the drivers side hub was a PITA to lock in, and acted weird last night. i'm guessing it's time to replace it, its an original looking one... I'd like to get a Warn 3/4 turn... Anything specific I need to know to get one for my axle type?
1969K10 is offline   Reply With Quote
Old 03-21-2006, 03:38 PM   #2
1969 GMC
1969 GMC's Avatar
Re: Time to replace a manual locking hub
Have you checked inside? One of mine was next to impossible to turn, so i took them apart, cleaned the pieces in a parts washer, and reassembled with white lithium grease instead of the 30 year old tar that was in there.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-21-2006, 09:14 PM   #3
JAKES 68GMC
Aluminum slot wheels rule...
I've found that sometimes mine turn hard, and sometimes the don't. Usually I just get a small adjustable wrench and turn them when I can't turn using my fingers. Probably a cleaning first wouldn't hurt.
JAKES 68GMC is offline   Reply With Quote
Old 03-22-2006, 01:30 PM   #4
1969K10
1969K10's Avatar
I've cleaned it once, and couple years ago. I guess I'll start there first. It's acting different this time, it will turn, but it turns too much, more than 3/4 turn, and it looks like the center portion that you turn is trying to come out of the center of the assembly...
thanks for the reminder to clean first, I've got this original on the drvr side, and the PO had replaced the pass side. The pass side is ALWAYS easy to turn, and has positive clicks when it's engaged, or dis-engaged. I keep thinking the driver's side one doesn't feel right, and must be about shot...
Old 03-22-2006, 08:39 PM   #5
1969 GMC
1969 GMC's Avatar
thats funny...my pass. side was brand new also. I guess the cast aluminum just doesn't like taking any abuse.
when mine acted up, the one WOULDNT turn at all, even when i rocked the truck, and put it in gear and drove around, and backed up. the other would just spin and not click.
1969 GMC K2500
1996 Honda Accord
Old 03-22-2006, 08:44 PM   #6
JAKES 68GMC
Sometime mine click, a lot of times they don't. But they still lock in and out.
Old 03-28-2006, 03:25 PM   #7
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
I use always have to use an adjustable wrench on mine. They will just spin round and round. They hardly ever click, but will lock in and out. I should probably clean them too, but haven't gotten that far yet.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 03-28-2006, 05:51 PM   #8
1969k10stepside
On my 69 k10 when I first got it in Dec. the lockouts would turn easy.
Now they will lock in 4x4 and will not unlock or move at all until I drive in 2x4 for awhile. I guess it doesn't matter because I am getting a disc brake axle with WARN lockouts.
1969k10stepside is offline   Reply With Quote
