03-21-2006, 02:37 PM | #1 |
C10 Club Tennessee
How to get Ignition Switch out?
Decided to just change my ignition switch since the damn thing won't turn all of a sudden. Can't seem to get the thing out of the dash. Trying to get my truck running before my board cookout this weekend. Any help would be appreciated.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-21-2006, 02:50 PM | #2 |
Thats the Hillbilly way
Re: How to get Ignition Switch out?
Key in switch ,there is a small hole upper left of key place paper clip or other wire in hole and push in turn key to left and the switch should come out .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 03-21-2006 at 02:51 PM. |
03-21-2006, 02:52 PM | #3 | |
Here is how I did mine last week: I took the two screws for my heater controls out and moved the heater controls out of the way and that made it a lot easier for me to remove the iginition switch. The key cylinder can be removed by putting the key in, turning the ignition to ACC, inserting a small wire (paper clip works great) into the little hole to press the release button. I just press the paper clip in and keep turning towards the ACC postiton. It should just pop out. Then you can unthread the retaining ring. Good luck.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
03-21-2006, 04:20 PM | #4 |
It's a catastrophic success.
Some more info.
http://67-72chevytrucks.com/vboard/s...d.php?t=187475 |
03-21-2006, 05:28 PM | #5 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-21-2006, 08:28 PM | #6 |
C10 Club Tennessee
I tried pushing a pin in that hole and the key still won't turn counter-clockwise.
03-21-2006, 08:35 PM | #7 | |
Some of these can be a BEAR so some WD 40 may help or a BFH .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 03-21-2006 at 08:36 PM. |
03-21-2006, 08:38 PM | #8 |
What's that funky smell?
Slight hijack:
Everytime I read about someone struggling with removing an igniton switch, I decide to give mine another try. After almost a year of trying, I finally saw a little bit of movement today. It still did not come out AND it made me bleed, but the switch actually moved a little!!!!!!! Thanks for bringing it back to my attention, guys.
Mike S 68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck 3 on the tree, 307, No power brakes or steering Factory Options - HD rear spring and Ammeter/Oil Gauges My truck blog My Car Domain page |
03-21-2006, 10:24 PM | #9 |
Here is a pic with switch tumbler removed so you can see what it is you are trying to push in on. that brass pin at the top corner is it
03-22-2006, 02:26 AM | #10 |
I used a screw in slide hammer. Came right out.
05-24-2013, 10:14 PM | #11 |
Slide hammer worked great on mine it was stuck and wouldn't budge
Posted via Mobile Device |
