brake booster prob
I have a fairly new booster maybe 4 months no issues ever. Today cold and wet. On way home first brake push full power great if I imediately push again less and so on. If I let it up for a few seconds good again. get home pull hose fool with it check valve and gromet all good hook back up. Seems the same then stops, and is all good, drive around a few minutes good as gold? Any thoughts on this or this happen to anyone else? could somthing have frozen up? The brakes always worked just less power assist like it was not getting enuf vac.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: brake booster prob
It sounds like a colapsed vacuum line from the carb/manifold. Does it have the steel line then a short rubber line to the check valve? Long rubber only hoses tend to flatten out and not allow vacuum to the booster at the required rate. That could be why it operates fine the first time and worse as you pump. Just something to check.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
