Old 03-21-2006, 09:59 PM   #1
jp-n-mallory71
jp-n-mallory71's Avatar
radiator support help
will a radiator support from a 71 GMC work on a 71 chevy. GMC has 2 headlights chevy has 1.
jp-n-mallory71 is offline   Reply With Quote
Old 03-21-2006, 10:05 PM   #2
Bob Moore
Re: radiator support help
You can use a spot weld cutter and remove the GMC headlight brackets and either weld or bolt on the Chev headlight buckets. Rest of it should be about the same.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
