Old 03-22-2006, 04:18 PM   #1
duke10
Active Member
duke10's Avatar
cab and radiator mounts
How difficult of a job is replacing the cab and radiator mounts on a 72 gmc short bed 4wd pickup? I just received the kit in the mail from chevyduty. I have no idea how involved the process is or where to start. Any comments or suggestions would be appreciated.
duke10 is offline   Reply With Quote
Old 03-22-2006, 10:02 PM   #2
duke10
Active Member
duke10's Avatar
Re: cab and radiator mounts
Should I post this in another section?
Old 03-22-2006, 10:48 PM   #3
avejoe
Custer had a plan too.
avejoe's Avatar
Very easy (assuming the bolts come loose).
1. Loosen all hardware really well.
2. Block truck as raising the cab with a jack will knock the linkage out of park. Probably do #2 first.
3. Remove and replace each mount one at a time.
4. Don't tighten all the way up until all the hardware is engaged.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 03-22-2006, 11:35 PM   #4
qksilver
pretty much as above, do one side at a time, use lots of WD-40 or something like it.
Soak those bolts for a couple of days
block the wheels, and get a wide board and make a slot, not too deep in the middle.
So you can put it under the rocker panel and it won't crush it or slide then jack that side up.
You dont have to jack it up too much.just enough to slide the mounts between.
DO NOT put your fingers or anything else between the cab and frame! I haven't but a buddy did
qksilver is offline   Reply With Quote
Old 03-23-2006, 12:21 AM   #5
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Just hope that the Previous Owner didn't weld the bolts in... I wanted to replace my rubber cab bushings when I first got the truck and found out it wasn't going to happen. So I've decided to wait until I'm ready to remove the cab completely to paint the truck to replace 'em...
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 03-23-2006, 12:42 AM   #6
rick0312
rick0312's Avatar
i just replaced my cab bushings....i cut the nuts off and replaced everything. I jacked the cab up by placing a few 2x8's under the outriggers this worked well I was able to spread the load out. Don't be suprised if you find some rot in the cab to frame mounts. I found some right where the bushings sit on these brackets. fortunately there was no rot where they connected to the frame so I reinforced them with some steel. The bolts in the front are accessible, but you have to pull the rug up. The rear cab bolts are under the gas tank. Since I was also replacing floor pans at the time i had everything out of the interior of the cab. I had to remove the gas tank in order to get to the rear bolts. this was my first time at replacing floor pans and cab bushings. It went ptretty smooth. good luck
rick0312 is offline   Reply With Quote
Old 03-26-2006, 10:59 AM   #7
duke10
Active Member
duke10's Avatar
When you replace the front mounts under the radiator do you have to remove the radiator and crossmember or what?
Old 03-26-2006, 11:45 AM   #8
chops333
yes youll have to remove radiator so you get the core support bolts out there a real pain sometimes good luck
chops333 is offline   Reply With Quote
Old 03-26-2006, 06:38 PM   #9
shifty
Questionable
shifty's Avatar
lots of pictures of this process - use the search feature on this forum and search for "mounts". you should find a few threads, some with pics. i lifted off my cab today and i'm replacing the mounts once i'm done w/my other work. the fun part is removing the front two
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-27-2006, 01:29 PM   #10
duke10
Active Member
duke10's Avatar
thanks
Old 03-27-2006, 06:24 PM   #11
shifty
Questionable
shifty's Avatar
ONE MORE IMPORTANT NOTE:
remove the ground strap that goes from the front passenger side cab mount up to the body. Don't ask me how I know to do this
(hint: i'll be buying a new ground strap soon )
