Old 03-22-2006, 04:47 PM   #1
usarmyoif3
doorpanels
i have a 72 gmc that has no door panels on it how can i put a set from a 71 back on it i have a good set off my 71 that im not going to use and i like them better then the 72 door panels anyways.
usarmyoif3 is offline   Reply With Quote
Old 03-22-2006, 05:04 PM   #2
4tiresngas
An American Soldier
4tiresngas's Avatar
Re: doorpanels
You can put the 71's on the 72. The problem comes when you try to put 72's on older trucks. The 72's have longer crank arms on the window regulator and latch to accomodate the thicker plastic door panels.
To install the older panels, you'll likely need the retaining bar that goes across the top of the panel. It is held on with screws...no big issue. On the bottom, you wil need to get the pop in nuts (metal or plastic...probably on the help aisle of your local parts store) and pop them in so you have something to tighten your bottom screws up with.
That's how I remember it. If I'm off, I'm sure someone else will chime in.
Good luck.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
