250 towing capacity?
I have a 3/4t pickup with a stock 250 and a 3 speed manual running 4.56 gears. I just won a car online, and wanted to know if my truck has the capacity to tow a 3,500lb car. I have upgraded to front disc brakes, and I will be using a trailer from uhaul with inertia brakes.
any thoughts? class 3 hitch is all I need right?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
Aluminum slot wheels rule...
Re: 250 towing capacity?
How far are you towing the car? I'm sure the 250 will have guts enough to pull a car on a trailer. Probably not the fastest ticket, though. Reviever hitch would help.
its all about the +6 inches
Are you gonna use U-haul... or are you just saying that name genericly? U-haul will say no.
There car transporter weights right at 2000 pounds, plus the 3500 of this car, they'll say your truck can't do it. |
Should work ok...............Plan your trip so you don't have to start that load from a dead stop on a hill.................
We pulled more than that in gravity wagons on the farm with our C-10, 250 3spd with 3.73's.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
uhaul told me I could tow my 96 bonneville, and my 69 camaro, without any problems. This is going to be an 80 malibu 2dr.....and I figure thats gotta weigh less than either one of those cars.
so, no hills, and we are ok? lots of clutch slip, or am I doomed on a hill.
#6 | |
by the book, you are rated to tow 6500 pounds.
#8 | |
I went thru the same thoughts when I went to bring back one from Arizona. Weight wise, have you considered a wheel dolly. The Malibu doesn't weigh as much as the burb I towed and it did well. Disconnect the drive shaft put good wheels and tires on rear and tow from the front.
i have done a lot of picking up vehicles last year, and used a tow dolley when ever possible and that was towing full size trucks. The rental would be cheaper, less weight and easier on the truck. You do have to be a little more carefull but depending on the distance would be a good option |
I think the 3spd is your biggest drawback.It`ll pull it,it`ll slow down a good bit on hills,downshift,etc.But,the 3spd has that high 1st.Like you said,just slip it.
It should do fine. I tow my boat & trailer (3500lbs) around with my 89 S-10. It only has the lowly 2.5L (151cid) 4-banger. The boat definately weights more than the truck.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
