Old 07-25-2002, 12:30 PM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
2wd lift kit?
All I can seem to find are lift kits for 67-72 4X4. I have a 72 C10 and wanted maybe 3-4" of lift, does anyone make a lift kit for 2wd?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 07-25-2002, 05:56 PM   #2
slam33
slam33's Avatar
No kits, You can go 1 1/2 to 2 inches on the front before you need to swap the upper a-arm for one that has a bend in it for the ball joint angle, AIM has that arm, it's good for about 4 inches. Rancho has 0-3 inch lift shocks. As for the rear, no one has taller springs, you can pick up about a 1/2 inch with 3/4 springs or make some spacers for the frame side that can give you 2 inches, or you can go air shocks. Anything more than 2 inches starts to pull the center bearing cushion out and the panhard bar pulles the rear end over to the left. To do it right you need an adjustable panhard rod. Other than that you can pick up some lift with taller tires. 32-11.5/15's look to fit about the best.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 07-25-2002, 06:17 PM   #3
Alexis
Member since 2000
Alexis's Avatar
for the rear you could use a newer rear tahoe spring, there have rear coils, this is NOT proven just a thought so you might want to look into that, they have some pretty big springs even if it not enough lift you can make spacers to fill in the space.
Alexis is offline   Reply With Quote
Old 07-26-2002, 04:53 PM   #4
Mike C
Mike C's Avatar
I think you can use the front setup for a 73-87 truck. We put a Fabtech 3" on my brother's 96 2 wheel drive Chevy. Looks cool. The rear may be difficult if you have coil/trailing arm setup. Add-a-leaf or blocks if you have leafs, or even new springs if you have 2 1/2" leaves. SOL if you've got 2 1/4 for replacements.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
