Old 03-23-2006, 04:47 PM   #1
zipgun
ZIPGUN
zipgun's Avatar
Wheel Cylinder Sticking ?
Hey all,
I recently replaced the rear brake shoes on my 1990 Burb. I cleaned everything with brake cleaner then installed the new pads. I adjusted the pads as per the manual and I now have the drivers side heating up quite a bit when I drive it. I believe the problem is with the wheel cylinder even though it isnt leaking. Anybody have any ideas ???
zipgun is offline   Reply With Quote
Old 03-23-2006, 07:44 PM   #2
screwballl
Tonawanda 454
screwballl's Avatar
Re: Wheel Cylinder Sticking ?
i just spent $500 on new axle seals (as mine is 3/4ton), cylinder and brake job.. the cylinder still leaks usually after fresh brakes on most chevys, especially with more than 50K miles....
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 03-23-2006, 08:12 PM   #3
a28doc
'87 V20 4x4
a28doc's Avatar
sounds as if maybe it needs backed out some more as it may be making contact with the drum a little which creates tremendous heat but thats what Id check first
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 03-23-2006, 08:42 PM   #4
zipgun
ZIPGUN
zipgun's Avatar
500 for seals !!! Yikes!! I am glad I only have a 1/2 ton. The passenger side seal was leaking when I bought it but I pulled the axle and put a new one in.
My burb has 120,000 on it right now. I love the thing it goes anywhere and it keeps my sons from fighting due to the cabin space. I am going to pull the tire tommorrow and back of the self adjuster more, if that doesnt work I'll replace the wheel cylinder. I hate having to pull the tire but the backplates dont have the cut outs for the adjusting tool. Thanks for the info fellas !!!
ZIPGUN
Old 03-23-2006, 10:18 PM   #5
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
Wheel cylinders are fairly cheap anyhow, but as Doc mentioned, make sure it's adjusted correctly. Also check the parking brake to make sure it's not stuck, and make sure you clean up and grease the contact points on the backing plates where the shoes contact them.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
