Old 03-23-2006, 08:29 PM   #1
farside847
farside847's Avatar
Slow Oil Leak
I have a leak, but for the life of me I cant tell where. Its not a big leak, but
enough to make a puddle in the drip pan I have after a month. My engine was
just rebuilt about 5k miles ago.
What are the comon areas for a leak so I can try and hunt it down?
Thanks!
PS - 307 V8 stock engine with the original valve covers and oil pan.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-23-2006, 08:48 PM   #2
northcountry67
northcountry67's Avatar
Re: Slow Oil Leak
I would look at the dust cover on the tranny to see if a drop has formed there. Unless the engine builder had a problem with other gaskets, the rear main is normally the culprit. You might also just want to check the valve cover bolts. I've found them only finger tight after a rebuild when the motor warmed up. Good luck and I hope it's something simple.
northcountry67 is offline   Reply With Quote
Old 03-23-2006, 08:55 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Slow Oil Leak
Valve covers or intake manifold end seals are common leakers.
Old 03-23-2006, 09:38 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Slow Oil Leak
Not much to go on but if you can't find it from the common places I would look at the back of the intake and if you have a mechanical oil pressure gauge
check the fittings behind the distributor. An electric op sending unit has been known to leak also. Some not so common places are, under the distributor base, behind the fuel pump mount, and the mounting gasket for the oil filter.
Can you tell what part of the engine it's coming from? I assume we're talkin oil and not tranny fluid.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-24-2006, 12:13 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Re: Slow Oil Leak
Go to the GM dealer and buy a bottle of UV dye that you use with a black light. It's about $8 for an ounce.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-24-2006, 08:46 AM   #6
76bonanza
76bonanza's Avatar
Re: Slow Oil Leak
The common areas for an oil leak in a chevy is anywere that has oil in it.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-24-2006, 11:01 AM   #7
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
Re: Slow Oil Leak
Chevy's and Harley's.......if they aren't leaking oil they aren't running right.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 03-24-2006, 11:09 AM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Slow Oil Leak
Get you some engine degreaser, go to car wash and hose it down clean,take it around the block a couple of times and get a flashlight and do some inspecting keep doing this until you get a drip to show.If its your rear main seal it wont show up until it drips out the weep hole in the dust cover.
sneakysnake is offline   Reply With Quote
Old 03-24-2006, 11:25 AM   #9
1969k10stepside
Re: Slow Oil Leak
My harley don't drip no oil but all my chevys are burnin oil.
1969k10stepside is offline   Reply With Quote
Old 03-24-2006, 11:25 AM   #10
76bonanza
76bonanza's Avatar
Re: Slow Oil Leak
Speaking of dust cover I do not have one over my flywheel I guess I should try and find one for my th400.
1968 c10
lowered 3" 4"
Old 03-24-2006, 12:00 PM   #11
cdowns
cdowns's Avatar
Re: Slow Oil Leak
put cardboard down on the floor to have a mark where it's dripping then just look up from there
Old 03-24-2006, 12:19 PM   #12
farside847
farside847's Avatar
Re: Slow Oil Leak
Thats kinda where I started, but it drips from my crossmember so it really doent tell me much. I need to clean the engine to track it down I guess....
Old 03-24-2006, 12:49 PM   #13
cdowns
cdowns's Avatar
Re: Slow Oil Leak
well if it's dripping from the front crossmember that eliminates the back of the engine// theres the hole(should be sealed with a short bolt with sealant) on the front of the block near the fuel pump,the fuel pump mount, the timing chain cover the front crankshaft seal , the front intake gasket,or the valve covers, oilpan gasket too// or it could be power steering???
Old 03-24-2006, 09:32 PM   #14
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: Slow Oil Leak
Harley's dont leak oil. They mark there spot.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
