Old 07-25-2002, 01:39 PM   #1
HIGH724X4
I need electrical help, Please!!
I replaced the triple gauge set (volt/oil/water) in my 67 camaro, I wired the new up, and now I have no Juice?? It turns over but No start. no headlights no radio no volts!!! Oil Pressure but no Electric, Can Someone Help???
72 CHEVY FLEETSIDE 4X4 K10
(SOLD TO JAMIE72,
BUT BLAZER GAL PULLED AWAY WITH IT LOL!!!)
Will Own one Again!!!
1967 CAMARO (PRO-TOURING PROJECT)
Lawrenceburg, Indiana..
AOL IM: kbillcad
HIGH724X4 is offline   Reply With Quote
Old 07-25-2002, 05:10 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Double and tripple check the wires to the amp guage...you have a problem somewhere ion that circuit.
Old 07-25-2002, 06:24 PM   #3
imdarren
imdarren's Avatar
I'm probably way out in left field. But I'd check fusable links. Is there one down by the starter?
I'm just wondering if you blew a fuse somewhere?
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 07-25-2002, 06:33 PM   #4
bigjimzlll
bigjimzlll's Avatar
are you sure you are replacing an amp meter and not a volt meter?..if your putting a amp meter in place of a volt meter you will need much, much bigger wire.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
