Old 03-24-2006, 03:53 PM   #1
Nima
Blue 67
Rear diff oil in wheel hub!
Hi guys/gals:
Well, I was getting ready to do front disc/front end upgrade. I also wanted to freshen up my rear brakes since I don't think anybody touch them for long long time. Anywasy, when I took my right rear wheel out, rear diff oil poured out from wheel hub. What does that mean?Is there any seal or something?
Thanks.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 03-24-2006, 03:56 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Rear diff oil in wheel hub!
Yep, you're seal needs replaced...and so do your shoes now too.
Old 03-24-2006, 04:16 PM   #3
Nima
Blue 67
Thanks Longhorn man. What does these seals called? Are they easily available?
Old 03-24-2006, 04:23 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
Rear axle seals. Auto part stores usally have them. Careful putting them in..I use a wood block with a hammer to install.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-24-2006, 06:19 PM   #5
Longhorn Man
I don't remember if there were any issues when i replaced mine last year, I know I had LOTS of issues getting brake parts, but the seals were pretty easy if I remember right.
I used NAPA, and honestly, wouldn't trust anyone else (as far as parts stores...not talkin resto vendors here) with parts this difficult.
Old 03-24-2006, 07:15 PM   #6
72armyswbtruck
72armyswbtruck's Avatar
Is it difficult to pull out the seals?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-24-2006, 07:17 PM   #7
Blazer1970
Blazer1970's Avatar
If you pulled out the axle shaft and gear oil came out, that is normal. On a full floating axle, the wheel bearings are lubed by the gear oil.
Blazer1970 is offline   Reply With Quote
Old 03-24-2006, 09:12 PM   #8
Nima
Blue 67
Oh boy!, I think I am gona need help with this seal thing. Longhorn man, about the brake parts, I see that most auto part carry them on their web site at least. Is there any specific part/parts which I am gona have problem finding it?
Old 03-24-2006, 10:46 PM   #9
Longhorn Man
Well, mine is a one ton, HO72 instead of the HO52... EVERYTHING was hard to find on mine.
If your truck is a driver, be sure everything is right before you disable it.
Old 03-24-2006, 10:52 PM   #10
TP from Cntl PA
TP from Cntl PA's Avatar
If he's talking about the C-20 in his sig, I bet that is what happened
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 03-26-2006, 05:22 AM   #11
4x4Poet
Yeah, what exactly did you mean when you said, "I took my right rear wheel out?"
And, did any gear oil get on the brake shoes?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
