Old 03-24-2006, 11:45 PM   #1
Streetmaster
Need some tranny advise for 76 GMC.
I've got a 76 swb, twd, 1/2 ton pu, that had an inline-6, with a saginaw 3 speed, and three on the tree. The motor was spent, so i decided to replace it with a .030, 9.0:1, 350sbc, with a performance retro-roller comp cam. The saginaw 3 speed, flywheel, and clutch assembly fit right up to the 350 sbc. This transplant was done last summer, meanwhile the trucks been sitting all winter long, and im getting ready to start working on it again. But thru the winter cold crap, i had thoughts of going with a TH350 instead of the saginaw 3 speed, and would like some oppinions on the pro's, and con's, of either the stickshift, or the automatic, in a 4,000 lbs. pu with 3.42 gears. The saginaw 3 speed, has a 3.11 first gear ratio, and the TH350 has a 2.52 first gear ratio. The truck will be a daily driver, with P275R60 tires. Please Advise ThanX
Streetmaster is offline   Reply With Quote
Old 03-25-2006, 03:51 AM   #2
78chevstepside
78chevstepside's Avatar
Re: Need some tranny advise for 76 GMC.
I replace my 6 banger three-on-the - tree with a 355 v-8 turbo 350. I replace the steering column with one from a automatic. The drive shaft bolted right up as did the crossmember. I like the auto 100 times better then the three speed that always got stuck in second gear( only when you had nice clothes on).
1978 c10 stepside 4/6 drop 350 vortec crate 2011 camaro ss2 6.2 automatic 2017 tahoe lt 2002 silverado lt 1500 5.3 automatic. 1981 el camino
78chevstepside is offline   Reply With Quote
Old 03-25-2006, 03:34 PM   #3
Streetmaster
ThanX man, i believe you sold me on the idea. Im gonna go with the TH350.
