Need help?
Hello all,
Been a while. I need some help? My engine was rebuilt by the previous owner and my block number is no longer stamped where it should be. I found the Bureau of Automotive repair/engine Identification tag. Is there a way to decode this to discover what the original block number was? OR Is there a place I can go to research it here on the web? I did go to the Bureau's site and it was not helpful. Thanks for the help!! Respectfully
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Need help?
Everybody will tell you to look on the block on the left side rear of the engine and you will see a casting number. It will look like this ( 3970010 ) if it is still there . The numbers are about a 1/2 inch long and should be easy to see after you clean the crud off. When you can read them then go to this website,http://www.mortec.com/.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: Need help?
Thanks for the info. I thought the number was on the front only. I will look and get back to you.
Respectfully
