Old 03-25-2006, 08:58 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Brake light still wont go off.
I have bench bled the M/C, installed new s/s front brake lines, prop. valve, calipers, braided brake lines, rear wheel cylinders, rear flex line, bled the system numerous times, gravity bled the system 2 times, and the brake light is still on. The new prop. valve is shaped differently than the original one. I purchased a new one from Chevy Duty. It seems like there is fluid at the bottom of the prop. valve. I am getting very tired of dealing with this problem. Any ideas? Or suggestions.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-25-2006, 09:21 PM   #2
truckdude239
truckdude239's Avatar
Re: Brake light still wont go off.
check the wire coming off the p vavle and follow it and see if it is grounding somewhere that will make the light come on
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-25-2006, 11:30 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
An easier way to do that, would be to unplug that brown wire and see if the light goes off. If it stays on, then the wire is grounded elsewhere.
Old 03-25-2006, 11:38 PM   #4
northcountry67
northcountry67's Avatar
It is likely that the switch in the p-valve is stuck from the previous brake problem. Do what Longhorn suggested and unplug it to see if the light goes off.
northcountry67 is offline   Reply With Quote
Old 03-26-2006, 12:12 AM   #5
Bob D
Rolled on Paint Club
Bob D's Avatar
What about the emergency brake? Do these trucks have a light for that? None of the idiot lights ever worked on my truck so I dont know if there is an indicator light for the e-brake.
Bob
Bob D is offline   Reply With Quote
Old 03-26-2006, 12:19 AM   #6
Longhorn Man
nope, the light is only for hyd problems
Old 03-26-2006, 12:22 AM   #7
Bob D
Bob D's Avatar
Oh well....it was worth a shot!
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Old 03-26-2006, 01:36 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Hows your brake pedal freeplay. You need to have some play before the brake rod starts pushing the master cylinder piston . I like to have about 1/4 to 3/8ths of an inch.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-26-2006, 10:25 AM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I did pull the wire off the prop. valve while the truck was running and the light went out. I will try to bleed it a few more times, and see what happens.
Old 03-26-2006, 11:55 AM   #10
chops333
i had this same problem on 73 chevy i had to go back and from end to end side to side bleeding each one untill the piston centered in the prop.valve i had a book that showed the procedure hope this helps
chops333 is offline   Reply With Quote
