Old 03-25-2006, 09:11 PM   #1
HotRod73
HotRod73's Avatar
Oil Leak
I just discovered yesterday i have an oil leak there is a plastic thing that is between my motor and transmission, bolts to my tranny and has a hole in the bottom... it covers the flywheel.... is it a flywheel cover??? anyways... i got oil leaking out of that hole... hope its nothing too serious... its been sitting for a few years till a few weeks ago when gpa gave to me...runs good other than this... hope its not a rear main seal what else could it be? its not the oil pan or tranny pan gaskets....
HotRod73 is offline   Reply With Quote
Old 03-25-2006, 10:26 PM   #2
68Stepbed
68Stepbed's Avatar
Re: Oil Leak
Is it bad, or is it just a drip? If a sbc doesn't leak, there's something wrong.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-25-2006, 10:28 PM   #3
HotRod73
HotRod73's Avatar
Re: Oil Leak
lol well it sat last week, there is a noticable amount on the ground nothing major but takes up about the size of a sheet of paper if you lay it down
Old 03-25-2006, 11:14 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Oil Leak
It sounds like oil from the rear main seal. There are instructions on 73-87.com for replacing it. If it isn't motor oil, then it is coming from the front of the transmission.
Other possibilities-leaking fom back of intake, leaking from back of valve cover, leaking from oil pressure sending unit (behind distributor on smallblocks). That one drove me crazy once until I finall found the source. It could also be the oil pan gasket.
Clean everything up and make sure you know where it is coming from before you start replacing parts. I have made that mistake too many times.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-25-2006, 11:51 PM   #5
flyboy
Re: Oil Leak
Definitely start with the cheaper things first. That has saved me a couple time in the past. But you aren't really going to see what it is until you clean that underside up. I have tried to chase a leak without cleaning stuff up and ended up replacing parts when all I needed was a new oil pan gasket.
flyboy is offline   Reply With Quote
Old 03-25-2006, 11:55 PM   #6
HotRod73
HotRod73's Avatar
Re: Oil Leak
alright, kinda hard but ill work it out and let you guys know what i found
Old 03-27-2006, 04:53 AM   #7
karl
karl's Avatar
Re: Oil Leak
always check the easy things first.one other possability is the rear cam plug. but most likley the pan gasket or rear main seal. its all a process of elimination.
karl is offline   Reply With Quote
Old 04-26-2006, 10:56 PM   #8
HotRod73
HotRod73's Avatar
Re: Oil Leak
well, i took off my plastic flywheel cover, right on the back of my motor, where the oil pan has a U shape that goes to block its leaking about right there in a small spot and i notice old oil caked on oil pan, so im ASSUMING its oil pan gasket as it leaks very slow which leads me to believe its not rear main seal or it would leak more, i could be wrong ill have to check it out more.
Old 04-27-2006, 12:05 AM   #9
ureckme
ureckmefixit2@cox.net
Re: Oil Leak
see if you can snug up the pan bolt to slow down the leak
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 04-27-2006, 12:07 AM   #10
ureckme
Re: Oil Leak
my new one doesn't leak yet
74 Chevy Short Bed
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
Old 04-27-2006, 08:02 PM   #11
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Oil Leak
Well, dog gone it, it looks as if that motor is shot---you are just going to have to pull it and give it to me and go buy a new one. If that does not appeal to you, then I would try tightening the pan bolts very easily and then look forward to a change out of the gasket. How many miles does that motor have on it? There may be just a gasket replacement coming or should you look forward to a rebuild.
piecesparts is offline   Reply With Quote
Old 05-06-2006, 01:53 PM   #12
HotRod73
HotRod73's Avatar
Re: Oil Leak
only 90k orignal miles
