Old 03-25-2006, 09:34 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
2 ???'s about lockouts????
First of all I got a dana 44 with newer WARN lockout hubs one it, how the heck do you get the inner hub guts out? I can't see a snap ring on outer lip like original hubs.
Next what are these worth? Original, blue knobs are faded but not chewed up. Outer rings are pretty good couple small scars on them.
Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-25-2006, 11:15 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: 2 ???'s about lockouts????
Hey Randy, the snap ring should be in there, but the inner hub sticks out past it. Usually I have to use 2 picks to get it out. The newer Warn's are a pain in the butt compaired to the older ones...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-26-2006, 02:25 PM   #3
teeitup
teeitup's Avatar
Thanks Chuck, I got the rings out and one sides gear, but know I cna't get the gear out on the other side . These newer Warn's are alot different.
1980 chevy swb 4x4
Old 03-27-2006, 12:00 AM   #4
72 CustomCamper
huh ???
I personally can't stand Warn hubs. My 86 has Warn's on it only until I can get around to putting a set of Spicers on it...
Old 03-27-2006, 02:00 AM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
take two of the allen head screws that hold the outer section on and screw them into the gear. put them opposite of each other and use them as handles to gently pull out on the gear. It should slide right off the end of the axle shaft as long as both snap rings are out.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-27-2006, 02:01 AM   #6
qksilver
Yep...
qksilver is offline   Reply With Quote
Old 03-27-2006, 11:46 PM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
Now that I think about it I had a problem on one side when I took my Spicers off. Even with the scews in the gear to pull on one side would not slide over the end of the axle shaft. Turns out the snap ring had been missing from the end of the axle shaft for some time. The gear had slid in and out causing the very end of the splines on the shaft to burr. The burr was on the outside lip of the snap ring groove on each spline. I had to sit with a little file and smooth out each spline enough to allow the gear to slide over it. What a pain.
Rob Z.
