Old 03-25-2006, 11:03 PM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Clutch help????
I am ready to drive the Blazer out of the garage for the first time ever, and I can't get this stupid clutch figured out. Got the driveshaft back yesterday from having it lengthened and it went in fine. Fire up the engine tonight for its first test, and the clutch starts screeching as soon as I push in the pedal. Get under and look at it and the fork has popped off again. It almost acts like its too short or something. I'll post a pic of the part number to see if anyone knows if its the right one. I can't decide if its the right one or not. Also not sure the throw out bearing is in right. Does the small end face the clutch? I will attach pix of the fork. Hopefully someone will know if its the right one. Thanks for letting me vent, and the help if you can. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-25-2006, 11:13 PM   #2
Karl Hoh
A little east of nowhere
Re: Clutch help????
If I remember correctly the big end goes toward the clutch. Can you post a pic looking up with the inspection cover removed? The incorrect placement of the release bearing could be the cause of all the problems.
Karl Hoh is offline   Reply With Quote
Old 03-25-2006, 11:15 PM   #3
red71cheyenne
Back in the sticks
Re: Clutch help????
Pics:
Old 03-25-2006, 11:23 PM   #4
red71cheyenne
Back in the sticks
Re: Clutch help????
Throw out bearing:
2011 K1500 Suburban
2014 K1500 Pickup
Old 03-26-2006, 12:35 AM   #5
GMCMAX
Active Member
GMCMAX's Avatar
Re: Clutch help????
Bearing looks backwards to me, big side goes towards the clutch.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 03-26-2006, 01:05 AM   #6
rkarr
rkarr's Avatar
Re: Clutch help????
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 03-26-2006, 01:10 AM   #7
qksilver
Re: Clutch help????
It's backwards, and there is way to much grease. Use a little, turn the throw out bearing around and it should be fine
qksilver is offline   Reply With Quote
Old 03-26-2006, 12:55 PM   #8
red71cheyenne
Back in the sticks
Re: Clutch help????
Dang it! I was afraid of that. Thanks guys for looking at it. If it wasn't for you guys, this thing would never be done. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
