Old 03-26-2006, 10:34 AM   #1
Nima
Blue 67
Need help with these bolts!!
Well, last night I started the front disc swap finally. Everything was going well on disassembly section until I got to these bolts. Oh man, for the life of me I could't move them. I thought there migt be load or something on them but I didn't see anything therefore I soaked them with penetrating oil. This morning I tried again, NOTHING!. Any ideas? Heat, Hammer, ....
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 03-26-2006, 11:07 AM   #2
jakeslim
Premium Level Member
jakeslim's Avatar
Re: Need help with these bolts!!
not related to these bolts, but in general stubborn bolts can be taken off with a drive impact tool(manual). I picked up one of these to remove a rotor(honda).You put the socket on and hit it with a big hammer, applies up to 200ft lbs of torque to break bolts loose
You may want to pick one up. I got mine at NAPA auto
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 03-26-2006, 11:22 AM   #3
cdowns
cdowns's Avatar
i'd spray penatrating (pb blaster)stuff from the backside for a couple of days then apply gentle heat to try and loosen them up// you have to take care about applying too much force(impact tools and long breaker bar extensions) especially on the smaller bottom bolts because it is very easy to break them off in the spindles
Old 03-26-2006, 11:27 AM   #4
CG
BlahBlahBlah
my brother had the same problem with his. he ended up using pb, heat and air wrench. here is the thread with peoples suggestions.
http://67-72chevytrucks.com/vboard/s...d.php?t=154613
Old 03-26-2006, 11:30 AM   #5
Nima
Blue 67
Thanks guys.
Old 03-26-2006, 02:24 PM   #6
Bob Moore
Nima - I don't know your complete plan but why are you disassembling at that location? If you are converting to disc brake don't you need a different spindle? I would remove the spindle at the ball joint location and not worry about the backing plate. Does your set-up use the original spindle?
Please don't flame me for asking - I'm just trying to learn.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-26-2006, 05:18 PM   #7
Nima
Blue 67
No, I am putting a new spindles as well. Actually that was what I thought this morning. Then I guess I should take the whole thing off at the ball joints.
Old 03-26-2006, 07:07 PM   #8
jay-dawg
chevelito
jay-dawg's Avatar
i agree. just take off the drum spindle at the ball joints and put in the disc brake spindles.
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 03-26-2006, 07:26 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I completely agree, I usually just remove the whole spindle and pop it into the scrap pile. That saves making multiple trips with the seperate pieces.
As a side note though, if I remember correctly, those bottom 2 bolts go all the way through and have nuts on the back . No biggie if they were to break off.
Old 03-26-2006, 08:04 PM   #10
72armyswbtruck
72armyswbtruck's Avatar
Heres a neat trick that I have used before, HOT WAX, yah yah don't laugh, take a long candle or even a birthday candle, heat it up so the wax is melting and then let the wax melt into the threads, then the wax hardens in the threads acting as a natural penetrating/lubricating oil that doesn't leak out, has worked wonders for me before, especially since I didn't have a torch
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-26-2006, 09:31 PM   #11
jay-dawg
chevelito
jay-dawg's Avatar
hmm...better stick that in my file. thanks for the tip.
jay
