Old 03-26-2006, 11:17 AM   #1
jakeslim
Premium Level Member
jakeslim's Avatar
Ahhh yes....Spring time is here! What are your project plans?
It's been a long rainy winter and i am ready to begin working on the trucks again. My plans:
69 blazer:
- New shock -fronts done 4/01/06
- New Springs
-Change diff fluids
- Clean under truck and POR 15 frame/bed(under)
77 blazer
- fix leaking rear axle..14bolt leaks a bit at one wheel.
- begin body work to prep for Paint (end of Summer)
- Convert to Electric fuel pump....tired of pumping gas in mornings to start! I have electric in my 69 and it's amazing
- MAYBE change out from my Qjet to an edelbrock....depends if the qjet can deal with the electric fuel pump pressure at start up....sometimes they overflow
many other things to come!
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 03-26-2006, 11:51 AM   #2
69TowRig
Re: Ahhh yes....Spring time is here! What are your project plans?
Good luck with that.
Whenever I find a garage with a house in my new home here in NC I will get to working on the Blazer again. For now she sits at my folks house waiting for that day.
2006 Plans for the K5:
- Convert to power steering
- Replace windshield frame and windshield
- Floorpans, inner and outer rockers
- Rebuild trans and t-case
- Slip in a 290Hp GM crate engine
That should take all year to get done.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 03-26-2006, 12:38 PM   #3
ClassicJimmy
FNG to resto/mod world!
ClassicJimmy's Avatar
Starting today! My Jimmy is getting all my attention this year. The list is long, but will be worth it in the end.
- Rear floorbed repair
- New pass door & both door innerds
- Frame off, sandblasted & coated w/many new parts
- Engine rebuilt to 383 stroker w/MPFI
- NV4700/NP205 swap
- Body repaired as needed & preped for new paint
I think that should keep me busy this summer. I just hope I can squeeze work in so I can pay for it all! Good luck to all you guys on your projects & make sure you post pics of your work, I know I will.
71 GMC Jimmy - under construction
75 GMC K25 Sierra Grande - under deconstruction
92 Chevy K2500 ECSB - sold
04 Nissan Titan ECSB Off Road - sold & missed
13 Ford F-150 Ecoboost (work truck) - sold
16 Ford F-150 Ecoboost (work truck)
ClassicJimmy is offline   Reply With Quote
Old 03-26-2006, 01:11 PM   #4
SLIMJIM
Going to restore the rolling frame. Patch the floors, and prime it. Would love to find a 69-70 parts truck, but it aint going to happen around here. None to be had.
SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD
SLIMJIM is offline   Reply With Quote
Old 03-26-2006, 06:01 PM   #5
vtblazer
vtblazer's Avatar
Spent the winter fixing/breaking/fixing again/tweaking in...now my project plans are to drive it and enjoy it!
(went out today even)
vtblazer is offline   Reply With Quote
Old 03-27-2006, 11:09 AM   #6
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
Blazer:
- Have trans rebuilt
- Replace outer rockers
- Cut out and replace rusted areas of passenger side bed, plug holes in body.
- Get AC working / replace fan motor.
- Replace windshield.
'69 GMC Flatbed
- Install carpet.
- Install electric cooling fan.
- Get AC working.
- Clean it up for show-n-shines and HAN
'69 GMC 2500
- Install HEI (done)
- Switch from column shift to floor shift.
- Install Offenhauser intake and Holly 390 4bbl carb.
- Install header and new exhaust.
- Straighten out dings and dents.
- Use for hauling home improvement materials.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 03-27-2006, 11:12 AM   #7
nathan_454
Blazer:
- Rear Discs
- Re-build Kingpins
- Shackle Flip or lift springs (ditch blocks)
- carpet
- re-do stereo
- re-do seats or get beards or something of the sorts
- fix drivers fender
- enjoy the hell out of it since i havent even seen it in almost 2 years.
nathan_454 is offline   Reply With Quote
Old 03-27-2006, 11:16 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
I plan to get my K5 running this year - still debating the engine. I bought the K5 from a guy who said it hadn't ran in I think 4 years, I'm pretty sure that was closer to 7 years. I finally got it fired up and it puked tons of oil - I'm pretty sure the rear main seal is trashed. I think I should pull the engine and get it rebuilt - the other option is to just replace the rear main seal and see if the engine is any good. Just not sure moneywise what to do.
I've got a 3/4 ton front axle to go in it. This gets me disk brakes up front. I have a 14bolt ff to go out back. I have a Detroit locker to slip in it before I install the axle.
Needs some time and $$$!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-27-2006, 08:44 PM   #9
Paul72
Paul72's Avatar
My Blazer is finally going to get the attention I've been meaning to give it for 5 years. I'm going to do a tub swap, repair the door bottoms, new fenders, TG, core support and hood. Also going to put in a 700R4 and swap the rubber onto the aluminum slots.
I plan on completing this by memorial weekend so I can enjoy it this summer too!
Look for posts/pics in the future on the progress.......
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 03-27-2006, 08:50 PM   #10
SOON2BLAZE
SOON2BLAZE's Avatar
Looking forward to loosing the top, have a pace edwards jackrabbit tonnaue coming, outter rockers will get replaced, GMC front clip going on and tpi motor and od trans in the next month or two.
SOON2BLAZE is offline   Reply With Quote
Old 03-28-2006, 10:30 AM   #11
aztxk5
I've already started.
Pulled the motor for paint and performance upgrades.
Steam clean the engine bay, paint and clean up wiring.
aztxk5 is offline   Reply With Quote
Old 03-28-2006, 11:48 AM   #12
raggedjim
raggedjim's Avatar
I hate to jinx myself this way, but...
'69 Blazer
Get carb adjusted (q-jet)
Drive the b@lls off of it!
'70 Jimmy
Finish drivers side floor pans, rocker boxes, etc. (passengers side done)
Get it running good
Pull the top off
Fix windshield frame (this looks like fun...)
start prepping for paint
Good luck everyone, I'll need it! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 03-28-2006, 02:25 PM   #13
NuBomb
NuBomb's Avatar
Like many folks here I've been working on mine for several years. Over the past few weeks I've been accumulating parts to finish mine and finally start driving it. Here's the plans
Install rebuilt TH350,NP205, and driveshafts
Install Painless (I Hope) chassis wiring kit
Finish painting the glovebox door, ashtray, rear deflectors, plastic grill, rollbar, and swingaway.
Install glovebox bought from Kelsfine
find a way to install seats out of 2001 Chevy HD
buy a 3rd row seat out of a suburban and fab mounts to have it removable.
Fatmat
Carpet
make rear panels to hold speakers
Final tune-up
And Drive!!!
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 03-28-2006, 02:52 PM   #14
Joe67
67 is sold
I'll finally get back to work on my '67
First up, a call to Inline tube for stainless steel brake lines from front to rear and parking brake cables
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-28-2006, 04:38 PM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
"GQ"
Only thing missing is the paint, too bad it will be 2007,
but I plan to drive it and enjoy it alot more this year
"ROADSTER"
*68 Front Clip (71-72 DD parts go bye-bye / sell)
*67/68 Front Bumper (Same as line 1 for bumper)
*67/68 Outer Brackets (Same as line 1 for brackets)
Replace the H20 pump, the only reason it is parked
Work out all of the problems w/ brakes so it will stop
Work out all of the problems w/ the lights so I can see
Work out all of the problems w/ the motor so it will go
*Will only happen if I sell or trade some of my stuff
"GODZILLA"
Hope to purchase this one from my new TN buddy
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-01-2006, 08:48 AM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
New floors and rockers new to be installed but its hard when shes getting driven every day..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-01-2006, 10:40 AM   #17
jakeslim
jakeslim's Avatar
well we broke the record in march for most rainy days and had about 26 days of rain in Nor CA...ouch. Still waiting for Spring since April is starting with rain....
Old 04-01-2006, 11:14 AM   #18
RANDY COX
RANDY COX's Avatar
Where should I start need to pull engine and clean and repaint and put in new (36,000) mile tranny 3spd,clean up engine bay need to get atleast one new inner fender pass.side, already did all three rockers and replace lower rear bottom quarters,uh let's see replace seat covers add radio,there's now end,would be really nice if I had power windows yadda,yadda,yadda.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
