Old 03-27-2006, 02:26 AM   #1
tjluke
Ho70 differential
Hello
I have a old ho70 differentail with a detroit locker i think could be a eaton
diff no is 3934635 when i pulled it apart it came out in pieces i think i have it assembled ok but not sure has anyone have any assembly pictures of one of these units it looks like a clamshell with 4 pins on the out side fit inside of the ring gear housing.my e-mail is tjluke@juno.com.
Thanks Tom
tjluke is offline   Reply With Quote
Old 03-28-2006, 03:16 PM   #2
69k5
Re: Ho70 differential
whenever you put the detroit back together it will look like a ball with 4 pins sticking out. if you press in on the springs all the teeth will mesh together. then it is together right. be careful or it will back apart. electrical tape works good to hold it.
69k5 is offline   Reply With Quote
