03-27-2006, 11:40 AM | #1 |
Heater control panel
Where's the light or is there not one? I dug around and couldn't even find a socket for a light on the heater controls??? I'll pop it out and check a little later today. If I should have to replace just a bulb somewhere or an assembly, where and what do I look for?....BTW, in case I've lost my mind, don't give it back to me if anyone should find it...I might hurt myself
03-27-2006, 12:06 PM | #2 |
Junior Member
Re: Heater control panel
I Know on an a/c heater control there is one on each side..
03-27-2006, 12:15 PM | #3 |
collector of vintage rust
If memory serves right,.......it plugs behind the section where the settings are written. It is a raised, almost triangular box.
03-27-2006, 12:18 PM | #4 |
Back in the sticks
There are two on A/C controls, one on either side. I'm not sure on non-A/C, but I only have one light on my harness for the Blazer, so I'm guessing there's only one light on them. Anyone else know for sure? Pics!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
03-27-2006, 01:12 PM | #5 |
Cause the Chicks DIG IT!!
Hey JRB if yours isn't on there, then next time you come into OKC hit me up. I'll go out and look to doublecheck but I'm tearing my old cab apart and I wont' need that piece and you can have mine.
03-27-2006, 03:35 PM | #6 |
Thanks Ya'll...it is a a/c heater control. I just got back from junkyard scavaging and I'll head on out in a bit and check it...I did feel two round holes near the outer edges backside of the faceplate but no lights...WRMZ71, I may take you up on that one weekend, if anything just as an excuse to scope out you project...Jason
03-27-2006, 06:23 PM | #7 |
Questionable
on my '68 it is just behind the letters on the left-hand side. the wire snaps off really easy on it, as i found out. i just yanked all of my internals out and plan on selling or trading them and pulled all the wires. i can provide pics if you need them, shoot me a PM.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-27-2006 at 06:23 PM. |
03-27-2006, 06:54 PM | #8 |
you like pics?
03-28-2006, 03:18 PM | #9 |
p i c t u r e s...matt, thanks for the pics. I found both of em tucked behind wiring, more wiring and heater ducting. I gotta get some bulbs to see if one works cause right now, the other one aint....the wire sorta popped off when I tried to get some slack... shifty, I sent you a PM. Thanks for the help Ya'll
03-28-2006, 03:21 PM | #10 |
Aren't pictures the best
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
03-30-2006, 09:03 PM | #11 |
Well, I replaced the bulb on the intact one and no light...will try to find the wiring diagram. Any sugestions on what all to check? I think i found where they go back to the fusebox, they're so tucked up that I wasn't for sure
03-31-2006, 12:54 AM | #12 |
Back in the sticks
Not positive, but if the gray wire has a plug on the end, plug it into the panel lights post on the fuse box, turn on headlights and check light bulbs. If it no workie then, buy new bulbs. I just can't remember if the heater light lead had a plug on it. Jeff.
03-31-2006, 08:25 AM | #13 |
67-72 Addict!
The heater light wire is tied into the dash harness with no plug. Just trace the gray wire from the loom.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
