Old 03-27-2006, 05:52 PM   #1
Michael MacDonald
Help with 4-speed linkage
Just put a Muncie M22 4-speed in a 66 chevy C10. It has a 350 smallblock but no hole in the block for the Z-bar bellcrank. How can I engage the clutch fork using the pedal?
Michael MacDonald is offline   Reply With Quote
Old 03-27-2006, 07:27 PM   #2
rodnok1
rodnok1's Avatar
Re: Help with 4-speed linkage
Is there a hole and it doesn't up with z bar?
When swapping engines/trans there are many varieties of clutch setups. Some have fabbed up brackets to adapt blocks with holes in different spots and if you converted from I6 to v8 and installed the engine in v8 spot the clutch z bar won't line up. If you can snap a pic someone should be able to help you.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
