Old 03-27-2006, 06:13 PM   #1
rigon4
rigon4's Avatar
HELP with bed sides
I have a 1971 2wd blazer and would like to know the best way to take the bed sides off the bed floor?? Also the best way to take the cab floor and bed floor apart??
rigon4 is offline   Reply With Quote
Old 03-27-2006, 06:18 PM   #2
vtblazer
vtblazer's Avatar
Re: HELP with bed sides
Grind the couple/few spot welds from the lower rear door pillar.
Grind the welds attatched between the rear of the bed and the floor.
Unbolt them.
vtblazer is offline   Reply With Quote
Old 03-27-2006, 06:26 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
^ He would know, Kurt has done this at least once
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-27-2006, 07:08 PM   #4
Rokcrln
Rokcrln's Avatar
Just wondering what is it you are trying to do by seperating all of it!
Rokcrln is offline   Reply With Quote
Old 03-28-2006, 10:48 AM   #5
rigon4
rigon4's Avatar
I'm putting bedsides on and fixin the bed floor. The bed sides are junk and i got a set of short bed sides i'm cutting down to use and the bed floor is fixable on truck but a have a mint long box floor I mite cut down.the truck aslo needs rockers, rocker boxs, windshild frame, and the driver side floor is not in th best shape.
Old 03-29-2006, 07:27 AM   #6
vtblazer
vtblazer's Avatar
Post progress pics, it will help others wanting to go the same route.
Old 03-29-2006, 10:30 AM   #7
rigon4
rigon4's Avatar
i will post some pics. In the last three days it is down to just the tub. It's the up side to being layed off. Doors and front end came off nice but cutting bedsides bolts off has taken a beating on the grinding wheels.
Old 03-29-2006, 06:21 PM   #8
vtblazer
vtblazer's Avatar
It's a whole lot easier to just tighten them until they 'pop' (snap/break)
Then just replace em later.
Old 03-31-2006, 10:57 AM   #9
rigon4
rigon4's Avatar
that is helpful but i would rather not risk rounding out the holes if i use the bed floor. and have not found spot welds could you take some pics to help!!! thanks
I'm lost in my own world!!!!
Old 03-31-2006, 12:01 PM   #10
vtblazer
vtblazer's Avatar
That's the whole idea behind breaking them off, they won't move, only bust.
Trying to turn them out is what rounds out the bed holes.
Try this thread, maybe it'll have something to help.
http://67-72chevytrucks.com/vboard/s...d.php?t=156022
Old 03-31-2006, 12:52 PM   #11
rigon4
rigon4's Avatar
so are the spot welds on the rocker boxs? I don't see any out back so are they on the front end. this thing has some rust so im almost working blind!!
Old 03-31-2006, 03:51 PM   #12
vtblazer
vtblazer's Avatar
Best pic I could find, sorry.
Can you see the 'cut out' section on the replacement quarter?
Just above the rocker panel. Tough to see but that's a before shot/trial fit.
That's where you'll find the spot welds.
Old 04-01-2006, 07:26 PM   #13
rigon4
rigon4's Avatar
Is the spot you are talking about level with the bed floor?? thanks for the help!!
