Old 03-27-2006, 10:40 PM   #1
Bhull2
Rear disc conversion, use front hoses on rear?
I am doing the rear disc conversion on my frame-off. I have a 72 K20 and am thinking I can use the front brake hoses for the rear calipers. There is a hole in the rear part of the frame, above the rear tire, just about where it is in relation to the front setup. The hose will go into the same spot, and this would eliminate running the center hose down over the differential like in the stock setup. I know this would require 2 hoses (one for each side) instead of the 1 in the middle, but would look cleaner, and keep the lines off of the diffrential. Just wondering if anyone has done this before?
Bhull2 is offline   Reply With Quote
Old 03-27-2006, 11:18 PM   #2
qksilver
Re: Rear disc conversion, use front hoses on rear?
It should work, make sure the hoses are long enough so that they pull or bind
qksilver is offline   Reply With Quote
