03-27-2006, 10:49 PM | #1 |
short sell Ford stock
how much POR-15 does it take...
i was wondering how much POR-15 it would take to coat a SWB frame? A pint, quart or a gallon? If anyone has used this stuff i would appreciate it. Oh yeah, is there any where else to buy the stuff other than online/? thanks.
03-27-2006, 10:53 PM | #2 |
Re: how much POR-15 does it take...
I'm not familiar with POR15, but I sprayed my frame with a black etch and it took about 1/2 gallon sprayable. Depending on the mixing ratio, you can get by with a quart of POR 15 if the reducer and hardener adds another quart. I did spray the top, bottom and inside the rails.
03-27-2006, 10:56 PM | #3 |
What ever you do use a good mask you dont want to suck that down your lungs
03-27-2006, 11:00 PM | #4 | |
Son Of Gravel Man
Daily driven 70 C10 longbed Its a work in progress Quote:
03-27-2006, 11:17 PM | #5 |
its all about the +6 inches
if you are spraying it, a resporator is REQUIRED...that stuff is NASTY, if brushing it on, then good ventilation is all that's really required.
2 weeks ago i did the rear 1/2 of my longhorn... from the back of the cab on back, including leafs, axle tubes (didn't do the pumpkin, too oily) and all crossmembers. I dod 2 coats, and it took a little over a quart. |
03-28-2006, 10:10 AM | #6 |
i used rustoliem and it took me aboyt a quart per coat
common sense isn't so common anymore |
03-28-2006, 04:37 PM | #7 |
chevy truck fan
tripleblack,
i used it to paint my frame. i have never sprayed before. i used right at 2 qrts. i sanded the frame to bare metal & then just started shooting. i like the way it turned out. word of caution!! for sure use a mask & what ever yo udo cover stuff up!!! it will go everywhere!!!. but it seems to stay on pretty good. good luck!!! rodstored-72 p.s. i also have a 2wd swb frame. Last edited by rodstored-72; 03-28-2006 at 04:37 PM. |
03-28-2006, 05:34 PM | #8 |
Dude, I just called around and found out the POR-15 comes in Silver, Gray, Semi Gloss and Black, what color would you go with, the truck is a longhorn that is blue and white and i am thinking of keeping the paint combo.
Suggestions BTW: Sorry to Hijack the post.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" Last edited by 72armyswbtruck; 03-28-2006 at 05:47 PM. |
