03-28-2006, 12:52 PM | #1 |
Questionable
tranny output shaft questions / request for used part in ATL
I'm in a dilemma. I wanted to have my driveshaft fabbed today and didn't even think to get a new output shaft for my T56.
After talking to j and slow in chat last night, they mentioned the TH350 and 700R4 output shaft should be about the same as a T56 output shaft - guys at the tranny shop say I'm full of crap, the 700R4 and TH350 are totally different and the guys typically don't deal with the T56. Two things: 1) Anyone know if the 700R4 and T56 share the same output shaft as far as splines and size go? 2) Does anyone here around here in ATL have a 700R4 output shaft? I can think of one board member I might ask nearby, but curious to see if anyone else around here definitely has one before I ask. Thanks, as always all I have left on the truck to finish is driveshaft, fuel delivery, install the harness and PCM and the hydraulic clutch linkage!!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-28-2006, 01:49 PM | #2 |
It's a catastrophic success.
Re: tranny output shaft questions / request for used part in ATL
A little reading.
http://www.chevyhiperformance.com/techarticles/60978/ |
03-28-2006, 04:42 PM | #3 |
There is a guy in Snellville that builds GM trasmissions. His name is Sid Neal. I don't have his #,but if you need it I can get it.
03-28-2006, 05:03 PM | #4 | |
Located in Buford,Georgia
Would you guys know of any junk yards that would have 68 c10 parts?
03-28-2006, 05:11 PM | #5 | |
Rottenwood Garage Member
03-28-2006, 05:15 PM | #6 | |
Questionable
You're the one guy I figured would have a pile of output shafts laying around!
03-28-2006, 05:24 PM | #7 |
I only have a few 700's, if it were turbo 350's you would be in luck.
03-29-2006, 08:25 AM | #8 | |
Great. I'll send you a pm of all the parts that I need.
