Old 03-28-2006, 06:50 PM   #1
nvrforgotten52
nvrforgotten52's Avatar
disc brake conversion
im in bad need of some front disc brakes to replace the old out dated drums on my 69 c-10. anyone have any good links out there that could help me out a little...
thanks,
david
nvrforgotten52 is offline   Reply With Quote
Old 03-28-2006, 07:07 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: disc brake conversion
I say spend the time and find a 71 or 72 with them already on, buy it and then swap the whole thing out axel to axel, so much easier and in the long run more cost effective once you start parting out the left overs
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-28-2006, 07:28 PM   #3
speedracer
Blank
speedracer's Avatar
I have stock ride height spindles from a 72 I'm looking to get rid of
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 03-29-2006, 10:59 PM   #4
shifty
Questionable
shifty's Avatar
ECE sells a front end brake upgrade kit and you can get lowered spindles with it.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-29-2006, 11:20 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
A simple crossmember swap will get you discs off of any 71 through 87 truck or 71-91 Suburban.
Or, if you want to lower the truck, just buy drop spindles from whatever vendor you choose and put the rotors and calipers on them.
I'll be posting a disc brake swap article for the FAQ section next week or so. I'm right in the middle of this right now on my Suburban.
Old 03-30-2006, 01:08 AM   #6
53burb
53burb's Avatar
I would be real interested to see the article on disc brakes when it is complete!!!!
53burb is offline   Reply With Quote
Old 03-30-2006, 01:15 AM   #7
skokie
skokie's Avatar
Me to..
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 03-30-2006, 06:20 AM   #8
Tx Firefighter
I'm just waiting on my spindles to arrive from ECE.
I'm using components off of a 75 model truck, combined with ECE spindles to convert my drum brake Suburban to discs.
Old 03-31-2006, 03:37 AM   #9
kevncar
Active Member
kevncar's Avatar
tx,
I've got everything from a-arm to a-arm off a 76. So I can just order dropped spindles and the rotor and caliper and all will work with what I have for my 67?
That would be cool
thanks
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 03-31-2006, 11:29 AM   #10
AWEGS72
AWEGS72's Avatar
I have a set i will be getting rid of after this weekend. Putting drop spindles on mine. Off a 72.
AWEGS72 is offline   Reply With Quote
Old 04-01-2006, 07:11 AM   #11
Tx Firefighter
Kevncar, you have three options:
1) Order a pair of 67 drop spindles and use the rotors, bearings, and calipers off the 76 model. This is the easiest, as it reuses your existing ball joints and control arms and steering components.
2) Order a pair of drop spindles for a 76 model, and change your ball joints to 76 model ones and reuse your control arms. You'll use the 76 model steering linkage, tie rods, etc this way.
3) Order a pair of 76 model drop spindles and swap the 76 model control arms onto your truck. That way you will have the 76 model ball joints to match the spindles. Again, you'll be using the 76 model steering linkage.
I'd do option 1. It's easiest and cheapest. Actually, that's exactly what I'm doing on my Suburban. I'll be reusing my old early model control arms and ball joints and steering linkage, combined with the drop spindles for the early truck. The brakes are off the 75 though. I'll have the article written Tuesday when I get back on the computer next time.
Old 04-01-2006, 11:22 AM   #12
Beto
So if I do option 1, then I will keep my stock crossmember and arms? All I will have to do is get the rotors and other stuff off a 76 chevy? Sorry if I sound stupid, but I'm just double checking...
Beto is offline   Reply With Quote
Old 04-01-2006, 01:11 PM   #13
Tx Firefighter
Yes, just buy a pair of drop spindles for your year truck from whoever you choose. I always use ECE myself. Then, the spindles will install onto your stock ball joints and control arms, and tie rod ends.
Now, you will need wheel bearings, rotor dust shields, rotors, calipers, pads, and caliper bolts from any 71 through 87 model truck with 1 1/4 inch rotors.
I just bought a beater 75 model truck myself. I ordered the drop spindles to fit my truck, and combined with all the 75 model brake stuff, I have disc brakes for very cheap price.
Old 04-01-2006, 09:45 PM   #14
Beto
thanks for the info! This sounds like a good alternative to buying a disc brake conversion kit. This is definitely going on the to do list.
Old 04-02-2006, 09:07 AM   #15
c10crazy
Like a Rock!
c10crazy's Avatar
Tx Firefighter, can I use the later model front swap brake parts with my 6 lug wheels?. Or do you think it's easier to buy a 6 lug conversion for $475 from GMCpauls?. I want to keep my 6 lug wheels but want discs too.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 04-02-2006, 11:32 AM   #16
Tx Firefighter
The problem is the 6 lug deal. All 1/2 ton disc brakes were 5 lug on 2WD trucks.
You can use the calipers, pads, spindle, etc from the later truck, but you'll still have to pony up and buy the aftermarket 6 lug rotors from a vendor.
Old 04-02-2006, 03:39 PM   #17
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I remember a thread in here about the 6 lug rotors on the 4x4s that will interchange with the half tons to keep the six lug wheels. It is something to check out. I had the post bookmarked but my computer hard drive crashed and I lost it.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-02-2006, 10:42 PM   #18
Jim_PA
I put all '72 (as already said, this works with other year trucks as well) brake and suspension parts on my '68. This way, I know what I have, and I can get what I need at any parts store when I need something.
It ended up costing more, but I have: all new ball joints, tie rod ends, calipers, master cylinder, prop. valve, brake lines, wheel cylinders, rotors, drums, brake hoses...... the list keeps growing
Jim_PA is offline   Reply With Quote
Old 04-02-2006, 11:17 PM   #19
byrd
Union Electrician
byrd's Avatar
Yeah and they are very costly and c10crazy in your case I would just buy the kit from GMC pauls. BY the time you get everything else you need and the $150-200 6 lug rotors, you would be better of imo
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 04-03-2006, 12:04 AM   #20
bluec10
bluec10's Avatar
Question for the guys who swapped in 73-87 front crossmembers - do the motor mount holes etc. line up? I'm not that far yet with my conversion. The front crossmember went in with only two new holes needed.
I also think that the 73-87 suspension is better designed than the 67-72 version. The control arm bushings are a lot bigger.
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 04-04-2006, 12:12 AM   #21
53burb
53burb's Avatar
ttt
Old 04-04-2006, 08:44 AM   #22
dallas71
dallas71's Avatar
from what i understand you do not have to swap the crossmember at all just the upper and lower a-arms and you are all set...
dallas71 is offline   Reply With Quote
Old 04-04-2006, 09:34 AM   #23
Tx Firefighter
That's number 3 I was talking about above.
