Old 03-28-2006, 07:43 PM   #1
76bonanza
76bonanza's Avatar
dynomat
I am dynomating my floor and doors. I do not want to remove my fuel tank can I stick the dynomat to the outside of the tank? Think it will help any at all?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-29-2006, 12:49 AM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Re: dynomat
I don't think it will help much sticking on the outside of the tank. Heck, the sound and hear are already in that by that point. One thing that i've learned is that anything worth doing is worth doing right!! good luck to ya
WRMZ71 is offline   Reply With Quote
Old 03-29-2006, 12:23 PM   #3
76bonanza
76bonanza's Avatar
Re: dynomat
Well I am looking at it more from a keep sound in from my speakers once installed. I will more than likely just do the floor and doors and kickpanels.
1968 c10
lowered 3" 4"
Old 03-29-2006, 09:13 PM   #4
longhorn70gmc
longhorn70gmc's Avatar
Re: dynomat
Forgive me for asking? What is dynomating?
Respectfully
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 03-29-2006, 10:14 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: dynomat
I would yank the tank out so that you can clean it out, before dynamat. I got a lot of junk out of my tank, and I'm still getting fine particles in the fuel filter. Oh ya, you will also need to replace the filler neck grommet too, because you will have to cut the old one out. Just my .02.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-29-2006, 10:46 PM   #6
76bonanza
76bonanza's Avatar
Re: dynomat
Tank is only 6 months old. Dynomat is a sound deadner
1968 c10
lowered 3" 4"
Old 03-29-2006, 11:03 PM   #7
shifty
Questionable
shifty's Avatar
Re: dynomat
I think it's Dynamat, not Dynomat. I could be wrong.
It won't help to do the tank. The whole principle of Dynamat is that you're adding weight to a metal panel so it's can't vibrate as easily and therefore it cannot relay noise by resonating. If you do not mount it to the outside body panels that you don't want to resonate/transmit noise, it defeats the purpose.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-29-2006, 11:05 PM   #8
longhorn70gmc
Smile Re: dynomat
Thanks my Board Brother!!!
Respectfully
Billy
Hub Cap Freak!
Old 03-29-2006, 11:34 PM   #9
76bonanza
76bonanza's Avatar
Re: dynomat
then I will not do the tank just the floors and doors.
1968 c10
lowered 3" 4"
Old 03-29-2006, 11:45 PM   #10
shifty
Questionable
shifty's Avatar
Re: dynomat
if you have a headliner, might also want to think about the roof and other items. meanwhile, check out this how-to w/pictures from ECE's website:
http://www.earlyclassic.com/tech.asp...%20Rods%20P6-2
it will give you all the instruction you need w/pictures and everything. follow it to the letter and you should be good to go. word to the wise: get a rattle-can of Eastwood's Rust Encapsulator and take a wire brush to and spray any rusty spots on the floor before you lay this stuff down. Once it's on there and sets, you gotta take a heat gun to it to get it off.
good luck!
Old 03-29-2006, 11:49 PM   #11
shifty
Questionable
shifty's Avatar
Re: dynomat
Oops ! Wrong link! I just edited my post with the correct link!
Old 03-30-2006, 02:17 AM   #12
CochinoFilipino
CochinoFilipino's Avatar
Re: dynomat
I would think that deadening the tank would be a good idea.
The tanks mounting points transfer outside vibrations to a big metal container inside the cab. Imagine all the sound resonating from near empty tank. Like having a big metal drum in there.
I'll be applying Edead to nearly everything.
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
