Old 03-29-2006, 12:20 AM   #1
iamthor
iamthor's Avatar
Transmission Cooler Installed!
Here it is. 3/4 Aluminum Tube. I used the factory holes with the welded on nuts (what are those for anyways???). I drilled the Bottom tube and made a "?" shaped brackets on the top since it sat 1 inch higher than the factory hole. Since I am not running a fan on the cooler I was able to leave the X bars in place. The cooler has about 1-inch clearance in front and back. Sounds like I did the same thing as Derail.
Rollin in my 64....GMC Suburban
iamthor is offline   Reply With Quote
Old 03-29-2006, 03:02 AM   #2
derail
derail's Avatar
Re: Transmission Cooler Installed!
Very nice! That was exactly what I was talking about and looks almost the exact same as mine. I guess "Great minds think alike."
derail is offline   Reply With Quote
