Old 03-29-2006, 12:20 AM   #1
Bryan H
Bryan H's Avatar
Anybody running a 3" dropped spring on front?
I'm thinking of going with a 3/5" on my 70 s/b and was wondering if going with just a 3" spring on front causes any alignment issues, tire leaning, or bottoming out. I know dropped spindle/dropped spring would be a better combination but I'm looking for a cheaper way besides cutting the factory front coils.(It already has disc on front) How about a 5" on the rear? Would I need to do a c-notch? Pinion angle problems? This truck will not be hauling much. Its just a weekend cruiser. I did a search and could'nt find any answers.
Thanks,
Bryan
Bryan H is offline   Reply With Quote
Old 03-29-2006, 12:39 AM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Re: Anybody running a 3" dropped spring on front?
I did a 3/5 drop with mine using shorter coils. No I didn't cut them I bought the actual ones. I drove around for like maybe a year without getting an alignment done but noticed the inside of the tire was wearing alot. I went and got it aligned and the guy said he had to put as many spacers as would fit in there to get it to go but its good. I suggest if you do this that you also buy some of the shorty shocks and get an adjustable tracking arm for out back.
WRMZ71 is offline   Reply With Quote
Old 03-29-2006, 12:57 AM   #3
randomhero472
randomhero472's Avatar
I just put 3" coils on mine, no alignment issues, but definatly get new shorter shocks and new adj. rear track bar.. i think the ride is just fine w/the coils IMO
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 03-29-2006, 07:10 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I used to use 3 inch drop front coils, they wrok fine. Unless something is bent or excessively worn on your truck, it will align just fine.
Personally, I just cut the factory coils nowdays. Obviously, it saves about 80 bucks, and no difference in ride or handling at all compared to 3 inch drop store bought coils.
