Full roll cage in a 72 blazer?
I want to put a full roll cage in a 72, what is the best way to do it? Should I wait before all the bodywork is done, or do it first? My blazer is in real good shape, but I would like to do a frame off resto-eventually. I want to put 1 ton axles and change color and add full cage tied to frame and mounted to seats. I have heard when the top is removed stuff moves? Any one have any good pics of cages like that?
Junior Member
Re: Full roll cage in a 72 blazer?
I've got a 72 and my cousin a 70 we both have cages in. The 70 is a full cage, mine has a full rear cage (nothing in front of the front seats). Ours were both put in with the truck fully assembled (well, other than the top of course). Maybe one of these days I'll mecome a memeber so I can post pics. Not sure if this helps or not.
Junior Member
Ok, maybe I can post attachments. Mine is the blue 72.
SKINNY TIRES RULE!
Nice pair of Blazers!
You're cage looks like a Smittybilt roll bar with a rear section added. Is it tied into the frame or just the body?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#5 | |
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
Junior Member
Both roll-cages are just to the body. Not sure what brand either are. The section rigth behind the front seats on mine, the PO had and never installed. Another cousin and I custom built the rest (well, mostly him, but I had fun too). I'll try to get some more pics of it soon.
On the orange blazer, that's mostly custom bulit too. Part of it came from another friend, and then was added onto. The design of each one is very different. We are both from Howell, MI. About dead center between Lansing and Detroit. My cousin and I grew up together, now live a few more houses apart, but are back sharing similar interests with families and K5's. Last edited by butzkeg; 03-30-2006 at 09:35 AM. |
#7 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Nice trucks- what size lift and tires are on those?
Nice Pics!
Junior Member
I'll try to do those pics tonight, as the soft-top should be cooperative in the 60 degree weather. It's warm enough for a top-down jaunt up-town.
The blue 72 has 6-inch leaf and 2-inch body lift. Rolling on 38x15.5x15's. Will probably go to a 36 or 37 next year. The hemi-orange 70 has a 6 inch leaf, rolling on 35x14.5x15's. |
There is a company in Pa that manufacturers full roll cages for 69-72 Blazers that you need to weld together. The pipe is smaller in size but thick enough for most applications and roll overs. They specialize in race car roll cage and frame building.
#12 | |
Mike
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#13 | |
Butz, welcome to the board! I'm over in Novi, just waiting for the weather to warm up a bit more and my truck will be rolling out of the garage with the top down. |
#14 | |
#15 |
Vtblazer-Nice,did you tie into the windshield frame or any other part of the body at all? That is exactly what I am looking for? How do you like the line-x interior? Looking at that too.
#16 | |
![]() Cage is tied into the frame via rubber bushings w/pads bolted together sandwiching the body. Rock sliders welded directly to the frame. Not tied into the windshield frame. (the two move very differently) Rubber coating works pretty well, just make sure your prep work is good. Last edited by vtblazer; 03-31-2006 at 08:36 AM. |
#17 |
Vtblazer-so if you had to do it again (roll cage) would you change anything or stick with your current set-up? I have heard some guys tying into the windshield frame and body (sides) to stiffen up when top is off. I am going to do a frameoff a 72 cst 4x4 -soda blast body, repair & paint, full roll cage, dana 60, 14 bolt ff 4.56 and detroits,600hp smallblock, race seats with 5-point belts and keep it street legal. This is going to be a slow and $$$ process!
#18 |
I'd be afraid of snapping the windshield frame if it was tied in and not able to flex.
Vtblazer that last shot is pretty good showing how the sliders and cage connect.... ![]() |
#19 |
Junior Member
Ok, here's a few more pics. Mine isn't tied in quite as nicely as VTBlazer, but it works for going to the dunes.
VT, that is a nice setup for sure. |
#20 |
Here is a link to mine.
http://www.wheelingarizona.com/forum...pic.php?t=6377 We did this back in November. We built it and tacked it with the top still on, then pulled the top off and finish welded it. Now there is a lot less movement with the top off. I still have gussets to add (triangulation) and I am going to tie the rear seat to the cage as well. It is welded directly to the top of the frame in four spots under the front seats. I am also going to tie the front legs and the back legs to the frame. So far I love it. I thought that I was going to get some vibration and increased noise from wending straight to the frame instead of using bushings, but that is not the case. It works great. |
#21 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nice looking cage set-up eric..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#22 |
Have any of you guys that have done cages kept your factory AC vent locations - I'm worried about the two vertical bars that form the very front hoop.
I guess I could do something like butzkeg did... Anyone ever run the tube down through the dash to the floor? - Is there even enough room?
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ |
