Old 03-30-2006, 10:14 AM   #1
beaterC10
Disc brake swap hardware
I have all the parts required to install disk brakes on a 1/2 ton. These were recently removed from an 84 or 86 1/2 ton. You get.
Upper and Lower control arms - need lower ball joints
Spindles, calipers, rotors, brake hoses - 1" thick rotors
Centerlink with pitman and idler arms - need two tie rod ends
Proportioning valve
Master cylinder - alum body, plastic reservoir
Four new rubber bushings for lower control arms
Asking $60 or trade for 73-87 parts. These are heavy, so no shipping.
beaterC10 is offline   Reply With Quote
Old 03-30-2006, 03:52 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: Disc brake swap hardware
Will these bolt up directly to the 67-72 chasis?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-30-2006, 10:16 PM   #3
qksilver
Yes they will, plus the replacement parts are cheaper and with the rubber bushings it will ride better
qksilver is offline   Reply With Quote
