V10 4x4 runs bad bad!
Alight people I have a 87 V10 350 tbi bone stock with over 180 thousand miles. When you have the truck in reverse or any of the fwd gears the truck will die, but starts right back up. So I replaced the idle are sensor and the throttle postion sensor still the same promblem, so I then bought a set of headers and a new ac delco O2 sensor still that problem. Also replaced the egr valve and rebuilt the throttle body, new tdent cable also. Truck acts like it have no power and drinks gas less than 5 miles a gallon and is bone stock! Dont know what else to try it throws no codes please help. Also forgot to tell you that it has a tune up new everything and is timed correctly and wired correctly
Re: V10 4x4 runs bad bad!
Welcome to the board, Joseph. Have you done a compression check? It sounds like you've lost some ring pressure. Also have a pressure test on your exhaust. Your Cat. converter may be bad.
Good Luck, and let us know what happens.
welcome a board from oklahoma, check your coil i would have never said this until a week ago i allways thought a coil either worked or it didnt but my truck acted the same way to the point that i replaced the carb and did a tune up as well come to find out the coil was weak? just a suggestion and keep us posted to what you find out.
square body trucks an addiction or an investment either way they consume all my extra time and money |
Thank you, For the welcome aboard I also changed out the coil and it dont have a cat only has like 2foot of pipe with glass packs! Sounds to me like I need to put a carb on it does anyone know what that takes?
pull the distributer cap and check for moisture inside the cap and also check for excessive play at the dist shaft by grabbing the rotor and wiggling side to side should be no noticable play in the distributer shaft.
i first saw the post "v-10" and i thought "wow, someone put a viper v10 in one of these..cool!!!!"
duhhhhh ![]()
1987 350 TBI lowered 5/7 |
think that I just need to put a new set of heads on there! Think that will solve that problem. Anyone got a boat or crotch rocket wanna trade?
Sounds to me like the distributor needs to be rebuilt. I have seen alot of these with this problem. Everyone changes everything they can to no avail. Rebuild the distributor or get a new one. Should fix it for you.
Support your local search and rescue team.... GET LOST! Originally Posted by DURRTY if some is good more is better too much ought to be enough........ |
pick up coil in distributor
No No
I'd start with some basic stuff. Fuel filter would be at the top of my list along with checking the actual fuel pressure. Then I would look for a vacuum leak and make sure the little brown wire by the air box was unhooked when you set timing and hooked back up when you were done. Then just for heck of it I would disconnect the plug-in on the transmission for kicks and see if the tcc solenoid was screwing with me.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
i have tried all but nothing seems to be working think I am gonna sell this baby
Happy to be here
![]() Join Date: Mar 2000
Welcome to the forum Joseph. If we can offer any more assistance please don't hesitate to ask. That's what we are all about. Be forwarned that this thread is on the verge of being closed as it is turning in to a "For Sale or Trade" offering, which in not allowed in the discussion forums.
#13 | |
#14 |
Thanks all the distibutor fixed the problem! Runs like a singer sewing machine now
#15 |
I knew it would fix it!! Glad to hear your back on the road.
