Old 03-31-2006, 01:08 AM   #1
Jim_PA
Front caliper bolts
Are they supposed to be really hard to turn in???
It goes in about 1/2 turn easy, then it gets really tight. What's going on here?
Jim_PA is offline   Reply With Quote
Old 03-31-2006, 01:42 AM   #2
Smallz72project
Smallz72project's Avatar
Re: Front caliper bolts
Try taking the caliper off and then threading it in, if it still does it, then I would say that the threads are messed up and need to be straightened out. Also clean up the bolt threads on a wire wheel or brush and use anti-seize on them. If the bolts do thread in, then your geometry of entry with the caliper in place is off. But to answer your original ?, no they shouldnt get tight like that only after half a turn. hope this helped.
Keep truckin,
Todd
Smallz72project is offline   Reply With Quote
Old 03-31-2006, 07:45 AM   #3
Jim_PA
Yeah, I was trying to put the bolts in (which are new) into the spinde without the caliper on. I was thinking I got the wrong bolts, but I guess not! Definitely helps, but man.. this sucks!
Old 03-31-2006, 08:19 AM   #4
Joe67
67 is sold
Keep truckin,
Todd
Good advice right there
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-31-2006, 08:35 AM   #5
Jim_PA
I bought them from you... do you remember having problems with them?
Old 03-31-2006, 09:15 AM   #6
Joe67
67 is sold
You did? Guess I don't remember that
I did have an extra set of bolts, they threaded into my calipers when I was doing some test fitting. I ended up using a new set I had instead.
Old 03-31-2006, 11:03 AM   #7
Jim_PA
So I guess it would be a gamble to just ram them in, and hope they fix themselves... I've seen stuff break this way - Anyone know what size tap I have to go get?
Old 04-01-2006, 09:55 PM   #8
Jim_PA
Well, FYI, they are 7/16 - 20 if anyone else needs the info... cleaned right up and the bolts go in fine. Now I can't find the rattle clip for the other caliper ......
Old 04-01-2006, 10:31 PM   #9
woodridge
woodridge's Avatar
Did GM go to metric threads on the later models? Might just be the wrong bolts.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 04-01-2006, 10:36 PM   #10
Jayss109
Active Member
Jayss109's Avatar
I got 1 (only) in a box of new calipers few months back that WAS metric. Go get a new one at the local auto parts store and try that
J
________
Fellis
Jayss109 is offline   Reply With Quote
