Old 03-31-2006, 03:46 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Pics for Txfirefighter
I don't know if you can see everything if not let me know. I've got everything done except this, well and the TV Cable which is going to be another nightmare.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-01-2006, 12:49 PM   #2
5150
C10 Club Tennessee
5150's Avatar
Re: Pics for Txfirefighter
ttt
Bryan
www.gmtruckshow.com
Old 04-01-2006, 01:21 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The one with the red connector looks to have two wires going to it right?
That's the 4th gear pressure switch then.
The yellow wiring loom, does it run toward the converter solenoid? I can't tell what's on the other end of it.
Old 04-01-2006, 05:20 PM   #4
5150
C10 Club Tennessee
5150's Avatar
Yes, the one with the red wire looms on it has two stubs on it.
TWO wires go along the yellow plastic wire guare over to another thing. I believe that is the solenoid. There are no other wires besides what you see here.
Here's another pic of the other side of the pan
I'm almost done.
Sorry for the crappy pic, I hope you can still make it out
Bryan
www.gmtruckshow.com
Old 04-01-2006, 06:08 PM   #5
Tx Firefighter
Disregard my previous PM...I think. I'm foggy, haven't done it in a few years. I'm researching it now to try and brush up.
I think you'll need to run 12 volts to the solenoid, then the other solenoid wire should go to the 1 wire switch.
Old 04-01-2006, 06:14 PM   #6
Tx Firefighter
Yes, I looked it up.
Run 12 volts to one of the two wires on the lockup solenoid. Now, run the other wire from the solenoid to the pressure switch with one terminal.
You're done now.
When the trans hits 4th gear, it will make ground and connect the 12 volts through the lockup solenoid to ground. This will energize the solenoid when the trans is in 4th gear.
Old 04-02-2006, 02:48 PM   #7
5150
C10 Club Tennessee
5150's Avatar
Does it matter which of the TWO wires on the solenoid I hook up to 12v or to the one terminal?
And do I leave the switch with TWO teminals unplugged?
Would you suggest running the a wire from the solenoid to the 4-pin plug and then from the outside the tranny to the 12V source?
Bryan
www.gmtruckshow.com
Old 04-02-2006, 05:47 PM   #8
Tx Firefighter
It shouldn't matter which of the two wires you connect to 12v and which goes to the grounding switch.
Use the little squarish 4 terminal connector near the shift shaft to pass 12 volt source inside the case.
Old 04-02-2006, 08:30 PM   #9
5150
C10 Club Tennessee
5150's Avatar
Do I leave the other pressure switches unplugged? in other words gut the wiring all together?
Bryan
www.gmtruckshow.com
Old 04-02-2006, 08:40 PM   #10
Tx Firefighter
Yes, other than the two wires mentioned above, there will be no wiring left inside the trans. The other switch remains unplugged.
Old 04-02-2006, 08:47 PM   #11
5150
C10 Club Tennessee
5150's Avatar
Cool, so the one with two terminal stays bare!
Awesome, I'll get right on it.
Bryan
www.gmtruckshow.com
Old 04-02-2006, 08:51 PM   #12
Tx Firefighter
It's been so long since I did this, I went and did a google on the subject. found a good article written by a board member on here, Ervin.
Old 04-02-2006, 09:17 PM   #13
5150
C10 Club Tennessee
5150's Avatar
I know I keep bothering you about this, but I just got underneath there and was pulling wires off and noticed that on the solenoid that is says
RED + BLK -
So I'm assuming that it does matter which wire goes to the 12v and which one to the ONE terminal switch.
Bryan
www.gmtruckshow.com
Old 04-03-2006, 12:45 AM   #14
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
For those of us reading this who have no idea whats going on, could you briefly fill us in or link to a post that does? Lol. Looks like a 700r4, but other than that, I have no idea.
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 04-03-2006, 07:15 AM   #15
5150
C10 Club Tennessee
5150's Avatar
Tx Firefighter is helping me wire up the overdrive on my 700r4 WITHOUT paying for the $150 kit from Summit or Jegs. He's helping me do it another way that gets the same results, but without the empty pocket.
Bryan
www.gmtruckshow.com
Old 04-08-2006, 01:09 AM   #16
GlennBrittain
I used Bow Tie Overdrives TV made easy kit, was the easy way out. There are alternatives on the TV cable set up. Try this site for more info http://iotech.no/corvette/technical/700r4/ .
GlennBrittain is offline   Reply With Quote
Old 04-08-2006, 01:16 AM   #17
Russell
Professional Grade
Russell's Avatar
I just went through this with my 77:
You want 12 volts coming in through the connector on the casing of the transmission, then going to the red wire (+) wire on the coil, then the black wire runs to one post on the silver pressure switch, and the other wire runs to a good ground source on the transmission.
Between the 12 volt fuse and tranny connector, you should have a brake switch that opens the connection when the pedal is pushed down, and a vaccum switch that will cause the transmission to come out of lockup under heavy load (useful if you're going up a hill, and the engine starts lugging down a bunch). The vaccum switch is optional however, I know of one or two guys who don't run them, but they have very powerful engines that don't get lugged down very easily. You can get all of this wiring in a form that literally bolts straight in from an 83ish + truck. It will have the vac switch, brake switch, a connector to plug into the fuse box, and all of the wiring needed from the fusebox all the way to the transmission. Just need to switch brake switches out, and run a vaccum line from your intake to the vac switch
That other pressure switch is used to lock the converter in 3rd gear as well, but myself, and a few others believe that is one of the reasons why the earlier transmissions were more prone to failure. If the converter is constantly locking and unlocking, it causes a lot of heat, which is what kills transmissions.
To test and make sure its working, go for a drive, get it going 45 mph, and let it drop into overdrive + lock the converter up, then lightly put your foot on the brake enough to light the brake lights up. The transmission should unlock the converter, and your RPMs should increase. If you are kinda lugging it right as it goes into OD, you should be able to notice a fair increase in RPMs.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-08-2006, 12:04 PM   #18
5150
C10 Club Tennessee
5150's Avatar
Wow, just when I wasn't confused. I have it run like Tx firefighter says. I have two wires the red one off the solenoid is going to the connector where I ran a 12V to. The black wire off the solenoid is going to the pressure switch that has one peg on it. That's the only wiring I have.
I have 4.10 gears so I know that will help.
Hope that's enough!
Bryan
www.gmtruckshow.com
Old 04-09-2006, 03:40 PM   #19
Russell
Professional Grade
Russell's Avatar
Ah, that will work as well -- It all depends on the type of pressure switch you have. Yours grounds itself through the valve body, while mine needs a wire run to the switch to provide ground to the switch itself
