Old 03-31-2006, 11:42 PM   #1
DANL
Ignition Switch Won't Kill Engine
Having following electrical issues after removing, resealing and reinstalling the engine:
1. Alternator will not charge.
2. Ignition switch will not kill the engine.
The ignition switch should not be the problem as I installed a new one today.
Can anyone recommend a process to determine the problem?
Thanks in advance.
...Dan
DANL is offline   Reply With Quote
Old 03-31-2006, 11:54 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Ignition Switch Won't Kill Engine
reinstall old switch
rage'nrat638 is offline   Reply With Quote
Old 04-01-2006, 12:03 AM   #3
DANL
Thanks rat, but I installed new switch because old switch would not kill engine. Unfortunately that did not correct the issue.
Thanks again.
...Dan
Old 04-01-2006, 12:13 AM   #4
rustyold69
student wrench turner
rustyold69's Avatar
i would check the grounds
1969 Chevy C-10 with 250 L6
2002 GMC Sierra 2500 HD Duramax with banks six gun
rustyold69 is offline   Reply With Quote
Old 04-01-2006, 01:41 AM   #5
jhow66
jhow66's Avatar
Unplug the 2 wire connector on alt. and see if switch will kill engine.If so the 2 wires are reversed. (above advice does not carry a warrenty).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-01-2006, 04:20 AM   #6
72armyswbtruck
72armyswbtruck's Avatar
I love your badges
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-01-2006, 09:40 AM   #7
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
THIS IS CORRECT! My friends 72 was doing the same thing after he installed a new alternator and a new alternator plug. He had reversed his two plug wires by mistake and had the same problem. Switched them back, and all was gravy.
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 04-01-2006, 11:35 AM   #8
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
I'm sure this will kill it.......
J/K had to
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 04-02-2006, 03:29 PM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
This might do the trick also!! JK check the alt plug.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 04-04-2006, 09:55 PM   #10
DANL
Thanks for the feedback. Chevy, black I'm sure your recommendations would work, but believe I will try option B first. Will try this weekend and keep you in the loop.
Thanks again.
...Dan
