Old 04-01-2006, 08:07 PM   #1
richierlb
body anc core support bolts
this makes me seem cheap but i've got urethane bushings for my truck ,but all my bolt are nasty. what i need to know is can i go to the local hardware and get the bolts and then install bushings. if so, what sizes do i need. and i know most people will tell me to use stock mounts but i want to at least try the urethanes and if i dont like em toss em and get stock mounts. thanks
richierlb is offline   Reply With Quote
Old 04-01-2006, 08:08 PM   #2
richierlb
Re: body anc core support bolts
by the way its a 70 chevy 1/2ton 2wd model
Old 04-01-2006, 11:05 PM   #3
alf1096
alf1096's Avatar
I dont know what size bolts they are...go to the hardware place and match them you but be sure and get good bolts it would suck if they broke
1970 Short Stepside----Process of Restoring
1983 1/2 Silverado
alf1096 is offline   Reply With Quote
Old 04-02-2006, 12:44 AM   #4
qksilver
spend the extra , jsut a little extra and use grade 8 and some lock tight.
Depending on the vendor a bolt kit is pretty cheap.
qksilver is offline   Reply With Quote
Old 04-02-2006, 01:09 AM   #5
Karl Hoh
A little east of nowhere
Match up the bolts, use grade 8 cad plated, the cad plating will help prevent rusting. I would use neversieze on the threads when installing, great stuff if you ever want to take it apart in the future.
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
