Old 04-01-2006, 09:09 PM   #1
D.B.
new here...ignition switch removal ques
Have 72 burb and a new ignition switch. the front bezel on the dash unscrews and every thing is loosed up, but the bezel wont come off. i cant get the bezel off of the ingition or ingition cylinder. looks like the bezel is supposed to unscrew and it should come apart. how does this work. thanks for any help. new here, been lurking and reading but just joined, love this place
d.b.
D.B. is offline   Reply With Quote
Old 04-01-2006, 10:08 PM   #2
eastern72suburban
eastern72suburban's Avatar
Re: new here...ignition switch removal ques
DB
It sounds like you didn't take the lock cylinder out first.
First disconnect the battery ground cable.
Remove the lock cylinder by positioning in "ACC." position and inserting wire in small hole in cylinder face. Push in on wire to depress plunger and continue to turn key counter clockwise until lock cylinder can be removed.
Then remove the metal ignition switch nut .
Pull the ignition switch out from under the dash and remove the wiring connector.
John
eastern72suburban is offline   Reply With Quote
Old 04-02-2006, 07:47 AM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
Do exactly as mentioned above....but if you dont have a key for it......like I have had to do on several occasions....you have to cut it out. I took a saw zaw to the back end of the key housing behind the dash and cut it off. Then it fell apart and came out. I am sure there is an easier was without a key but I couldnt figure it out. When doing this you have to replace the cylinder housing also.
Where in Virginia are you from?
72freak is offline   Reply With Quote
Old 04-03-2006, 03:11 PM   #4
D.B.
Thanks for the help. I think im going to have to cut it off, it wont budge at all. i have a new cylinder and switch so it wont matter anyway. Im in roanoke.
D.B.
Old 04-17-2007, 03:12 AM   #5
truckminded
Junior Member
ttt
truckminded is offline   Reply With Quote
Old 12-19-2010, 11:12 PM   #6
David67
David67's Avatar
Does this work for a 67 C10 as well? Thanks!
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 12-19-2010, 11:33 PM   #7
67swb72klb
67swb72klb's Avatar
should b no prob
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
